Some folks were asking for this feature, so here’s the app for you:
http://build.smartthings.com/projects/xively/logging-thermostat-status-to-xively/
Please note that I don’t own an ST-compatible thermostat, so I have only tested it in a simulator. Let me know if it works or not.
Enjoy
/Hack
Sean
(SStozki)
January 21, 2014, 8:53pm
2
I have it working with a Nest and 2Gig CT 101 thermostat.
Excellent, this is awesome! Thank you so much for writing this up. This is working with my Filtrete 3M-50. Just thinking out loud, you could probably do the same thing for all of the SmartThings Multi’s and graph that too!
You’re welcome. Yes, it’s just a matter of adding few lines of code. There’s however a limit how often you can post to Xively feed.
zach
(Zach)
January 21, 2014, 10:59pm
5
I can’t seem to get any data from my Nest.
I have the TemperatureLogger working fine, so I know I have the API Key and Feed ID setup correctly.
zach
(Zach)
January 23, 2014, 10:16am
6
I finally got a temp reading from my Nest thermostat, but only one and no operating state yet.
Here is the temperature readings from my Multisensor:
Here is the reading from my Nest:
Yes I changed the Channel Name, I also changed the Channel name in the SmartApp:
* ThermostatLogger. Logs thermostat temperature and operating state to Xively feed.
* See http://build.smartthings.com/projects/xively/ for more information.
* Author: @kernelhack
* Date: 2014-01-21
preferences {
section("Configure") {
input "xi_apikey", "text", title: "Xively API Key"
input "xi_feed", "number", title: "Xively Feed ID"
input "thermostat1", "capability.thermostat ", title: "Select thermostat"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
// Subscribe to attributes, devices, locations, etc.
subscribe(thermostat1, "temperature", handleThermostatTemperature)
subscribe(thermostat1, "thermostatOperatingState", handleThermostatOperatingState)
def parseHttpResponse(response) {
log.debug "HTTP Response: ${response}"
def writeChannelData(feed, channel, value) {
def uri = "https://api.xively.com/v2/feeds/${feed}.json"
def json = "{\"version\":\"1.0.0\",\"datastreams\":[{\"id\":\"${channel}\",\"current_value\":\"${value}\"}]}"
def headers = [
"X-ApiKey" : "${xi_apikey}"
def params = [
uri: uri,
headers: headers,
body: json
httpPutJson(params) {response -> parseHttpResponse(response)}
// Handle temperature event
def handleThermostatTemperature(evt) {
log.debug "Tempreature event: $evt.value"
writeChannelData(xi_feed, "TempUP", evt.value)
// Handle thermostatOperatingState event
def handleThermostatOperatingState(evt) {
log.debug "OperatingState event: $evt.value"
def opState = 0
if (evt.value == "heating") {
opState = 1
} else if (evt.value == "cooling") {
opState = -1
writeChannelData(xi_feed, "OperatingStateUP", opState)
I’m using this for the Nest Device Type https://gist.github.com/Dianoga/6055918
Anyone know what it is I’m doing wrong?
Yes, this Nest thermostat app does not generate thermostatOperatingState events.
zach
(Zach)
January 23, 2014, 2:16pm
8
So is it that I can’t get Operating State from a Nest? Or do I need some different code in the Device Type to do it?
I have only gotten one Temp reading sent to Xively in the last 14 Hours, shouldn’t I be getting more than that?
Your best bet is to contact the author of Nest device type and ask if it’s possible to get current operating state from the Nest and if so, update the device code. With regards to temperature reading, is it being updated in your smartphone app? You can also look for clues in IDE logs (https://graph.api.smartthings.com/ide/logs )
rjlo
(rjlowe)
June 6, 2014, 5:23pm
10
Sean:
I’m new but this objective will be one of my first. Can anyone describe in more detail the exact data being extracted, Ie. Does it include all of the following 1) device state (on/off) 2) Device Temperature assessment , and 3) device setpoint?
rjlo
(rjlowe)
June 6, 2014, 5:37pm
11
Does anyone know if the CT 101 sold under Iris at Lowe’s is the same thermostat?
Sean
(SStozki)
June 6, 2014, 8:07pm
12
@rjlo yes, that is the same one I have. It works with Smartthings.
tslagle13
(Tim Slagle)
August 22, 2014, 6:04pm
13
@Ben
Can you pull this from the archives? I’d love to do some of this stuff. I apparently missed this sometime ago and would like to incorporate it
pstuart
(Patrick Stuart [@pstuart])
August 22, 2014, 6:06pm
14
@tslagle13
Feel free to use my modified one:
Mine doesn’t rely on subscribe, but it could…
Just use this with pollster and refresh at your desire, I do 10 minute samples.
https://github.com/pstuart/smartthings/blob/master/logger.groovy
tslagle13
(Tim Slagle)
August 22, 2014, 6:11pm
15
@pstuart
I take back all the things i’ve said about you
tslagle13
(Tim Slagle)
August 22, 2014, 6:37pm
16
This is amazing! So sad i am just seeing this. Totally behind the times aparrently! lol
pstuart
August 22, 2014, 6:43pm
17
Yeah, works with almost all data point type devices. Great to see temp, humidity and other statuses over time in Xively.
bigjay2050
(Raphael Turnerstone)
August 29, 2014, 11:26pm
18
Tried to download this @kernelhack but it takes me to the home page?
bmoffett
(Bryan)
August 30, 2014, 3:22am
19
Patrick, I think I’m missing something obvious. Got my Xively account set up, but I’m seeing an error response to the feed put: “Datastreams stream is invalid”.
I tried creating a channel for one of the items in the feed - do I need to create a channel in Xively for everything I want to log?
pstuart
August 30, 2014, 2:18pm
20
So you have a develop device in Xively set up? Got your API key? Feed URL?
The channels should be created automatically once you send data to it.
