Hi @joemill, no problem. Here’s what you should now do:
Once you’ve added the devices to ST, you now want to go into Damage & Danger and select Leaks and Floods. Provide a name, like “Dishwasher Area” and tap next. Select your utilitech moisture sensor, pick what you want to do for notifications, and then under “Turn on these alarm”, select your shut off valve. If you used the code I provided above, your shut off valve will be in that list.
