Synthesis
(The Viking AKA "Holy Crap You're a Giant!")
21
As stated a couple of times, yes.
If your hot to the box is from a single point (breaker), then you can just backwire into one spot, then a short jumper from the second spot into the second switch hot.
Same for neutral as needed.
Ground, you need to wire nut or use the screw point at the back of the box (if metal) and run individual leads to each ground screw.
Theoretically but itβs still good practice to run a ground wire to the switch it outlet. Some Legrand Adorne switches and outlets ground the mounting plate and the switch grounds by contact when you push it in place. https://youtu.be/a6MICaGiVS0?t=59
