ZLL RGBW bulb not so warm white
I bought a Zigbee led driver for my RGBWW / RGB+CCT LED strips, but the warm white was not so warm color temperature.
The lower limit of warm white was set to 2700K, couldn’t set lower, but I saw the WW leds fully illuminated together with dim illuminated CW leds.
I noticed that my Hue candle goes down to 2000K.
I went looking for the DTH of the ZLL RGBW Bulb and changed the 2700k to 2000K. Now the CW leds are off.
PS it is not a Gledopto specific problem.
I returned zigbee led candle lights that were also not so “warm white”. Also due to the lower limit of 2700K?
With the LED strip I could clearly see that the CW leds were still shining.
What’s the brand and model of the various devices involved?
I had a Osram/Sylvania candle E14 that I returned because of the not so “warm white” color temperature.
I couldn’t see the leds inside the bulb, but with the knowledge now, I think that the lower limit of 2700K, set by the SmartThings internal driver (local) was not low enough to get the bulb in warm white (WW).
Can’t confirm it, I returned the bulb. Maybe others here have the same experience with RGBW or RGBWW lamps.
The same driver I modified to 2000K-6500K and now I have a better result.
Hope that it helps others, this information.
Grtn Ben
PS the LED driver now is a Zigbee device from Gledopto, the RGB-CCT version, together with RGB and CW/WW ledstrip.
