Hi
Just bought a zipato Micro mototorcontroller which I Will use for my window blinds. It showed up in ST as a metered switch. I use Amazon Alexa to control the blinds. It is awkward to say turn on window or turn off window. Does anybody know if there is a better device handler for this?
As a matter of fact… I do believe it’s already in there
Using native integration only allows you to say turn on/turn off a switch. If you want something more natural, you need to use a custom skill. I totally recommend EchoSistant, just because I wrote the code to open blinds for @JDogg016 ![]()
Thank you. I Will check out your suggestions.
