Hello;
We have a 3-Series Door Sensor (https://www.centralite.com/products/door-sensor) which supports ZigBee Home Automation 1.2 and we want to get notified (ZigBee attribute reporting) when the sensors on/off status has changed.
We are using Digi XBee Pro S2C module as a ZigBee coordinator, we have configured it according to the Digi’s knowledge base. We successfully communicate a ZigBee HA 1.2 siren from another vendor with the coordinator.
We are responding to the 0x0013 message from the sensor with a 0x0005 (Active EndPoint Req.) message the sensor replies with Active EndPoint Response. However, every 12 seconds; the sensor leaves the network and rejoins with another 0x0013 message. This goes on and on until the sensor goes back to the sleep.
Is there a special message for the device that makes it stay joined?
