Hello @Mariano_Colmenarejo how are u?
Please, can u add this device on your Edge driver?
Its multi gang switch 3 buttons.
Thank you very much!
Hi @guipaviani
I take note to do it in the month of August, until then I do not have access to the CLI or a pc
It’s a bit weird that it only has one endpoint and you say it’s a 3 gang switch
Hello to all.
I am having lots of problems since the old IDE drivers are not supported. I have all my house set up on these switches:
Lonsonho-interruptor inteligente Tuya Zigbee, pulsador de luz de 220V, Compatible con Alexa, Alice, asistente de Google Home, Zigbee2mqtt - AliExpress
unfortunatelly one of them is dead, and I need to get a new one and that’s where problems start.
I am not able to add this multi switch anymore the same way I did before. When I add it it is only available as a single one gang switch. I tried all od Mariano’s drivers and other available on the internet. None works.
Previously I was using Zigbee Multi Switch with child switch. It worked fine.
Any help how can I install an EDGE driver for those switches?
This is how currently it looks like in Groovy IDE:
I am assuming you tried @Mariano_Colmenarejo “ZigBee Multi Switch and Child Mc” Edge Driver. If you didn’t try it.
When you say it didn’t work what happened?
Were you able to switch to that driver and then the Switch didn’t work?
Or the app won’t let you switch to that driver? In this case @Mariano_Colmenarejo would need to add the fingerprints to his driver assuming the device is compatible.
I can’t switch to that driver -I get a message that it is not compatible fingerprint.
In that case @Mariano_Colmenarejo would need to add the fingerprints to his driver assuming the device is compatible.
Hi @Sebastian_M
Hello @Mariano_Colmenarejo how are you?
Please, can you add this device on your Edge driver?
It’s a multi gang touch switch with 3 buttons.
That would be great
Thank you so much, this worked for me.
I’ve had a couple of these Zemismart devices that worked perfectly with the SangBoy DTH for the past couple of years - then suddenly stopped working.
For reference this worked for these TS0044 devices:
These devices do not work with the zigbee multi switch and child Mc driver
should work with @erickv driver if their fingerprints are added
@Mariano_Colmenarejo works fine with edge driver: Zigbee Multi switch and Child MC
Thank you so much.
I have a 3 gang switch, Is there a way to show all switches independently?
Ok now I see thanks
