Sorry if this has been asked before but all I can find are comparisons to z-wave (not z-wave plus) and zigbee!
I have been going back and forth trying to decide between z-wave and zigbee. From what I can tell, zigbee has better battery life than z-wave. However, the ecolink z-wave plus sensors (tilt and door/windows) are rated for 5 years. So is it accurate to say z-wave plus has the longest battery life?
I also read that cheap zigbee devices have a faster response time than cheap z-wave devices. Does that include ecolink devices? Does that still hold true for z-wave plus? I am mostly referring to motion and door/window sensors.
Another common point is that zigbee devices are typically smaller than z-wave due to lower power requirements. Is that not true for z-wave plus since it also has longer battery life?
And more out of curiosity as it shouldn’t really matter: is the z-wave plus device limit also 232 devices? And max 4 hops?
Essentially I had decided to go with zigbee despite wifi interference reliability concerns (I would just make sure their frequencies are far apart), due to longer battery life and faster response times. But after looking more into z-wave plus I’m not sure those same conclusions are correct. Also, z-wave has the benefit of using hard wired outlets as repeaters for a cleaner look. I am using lutron caseta switches so unfortunately can’t use the switches as repeaters, and zigbee seems to only have plug-in style outlets.
What are everyone’s thoughts?
