I burnt a few hours and learned all the basic functions of the remote. For a few bucks on the Internet, this is a must have for remote controlling your Z-Wave devices on you ST Hub, worth it just to easily factory reset a device that is having paring issues. This item needs to get fully integrated into ST, cause as of now you can only control the Z-Wave devices on your Hub. We should be able to get this to be installed on ST’s and program the button on the App to do any on/off/dimmer/variable function. Would be great if the GE Link Bulb (Zigbee protocol) was functional with this unit via the hub. Remote should tell the hub to trigger any device on any protocol, needs some integration…
But here’s my basic setup notes, cause GE’s small handout is cryptic…
+UPDATED - 2/17/2015 - ADDED REMOTE CLONING SECTION
45600 REMOTE - BASIC SMARTTHINGS SETUP
-Ensure Remote is not already on a Z-Wave Network (Reset/Clear) and to clear all devices from it (if already installed in ST, then use Removal procedure below, prior to Resetting/Clearing remote):
-Hold Setup till Red/Green flash twice.
-Type 969, complete when green flashes twice.
-Note that none of the remote on/off buttons flash now (all devices cleared, remote is blank)
-Install (Add) GE 45600 Remote to ST:
-In ST App, +, + Connect New Device, Searching
-Type 967, flashes green rapidly till connected to App/Hub.
-When App says 1 connected, Select Found Item at the Bottom (Z-Wave Remote)
-Name Device “GE 45600 Remote”, Next, Done.
-Note - the All On/Off feature will not work for all Z-Wave devices currently assigned to the ST Hub, see All On/Off Feature below.
-Remove (Delete) GE 45600 from ST:
-In ST App, Things, Select Remote Setup Icon, Preferences, Remove, Uninstall
-Type 967, flashes green rapidly till removed from App/Hub.
-When App says Success, Press OK and item is removed from Things page.
-Always good to perform a Remote Reset/Clear (above).
GE 45600 REMOTE - PROGRAM/ASSIGN DEVICES TO BUTTONS
-Remote must already be setup/assigned to the ST Hub per the above procedures.
-You can program up to 18 buttons, use the Setup/Shift button to access buttons 11-18.
-Setup (Add) Device (Light/Switch) to a Remote button:
-Press Add (Red Blink), Press Light (Red Blink), Press desired Number (flashes green rapidly)
-Press button on actual device, complete when green flashes twice.
-Setup (Remove) Device (Light/Switch) to a Remote button:
-If you press the Delete button vs the Remove button below, you may Delete (Reset the Device to Factory Settings) the device from your ST Hub; to recover the device you may need to force remove it from the App, then Reinstall it again.
-Press Remove (Red Blink), Press Light (Red Blink).
-Press desired Numbered button on the remote to erase the device from (flashes green twice).
-Note that when an unprogramed number button is selected, it will not flash at all.
GE 45600 REMOTE - ALL DEVICES ON/OFF FEATURE
-Allows you to quickly turn all Z-Wave devices assigned to the ST Hub On/Off with one click.
-Strange, but I’ve noticed this will work all Z-Wave devices setup on the ST Hub, whether they were added to the remote or not. Also, it only works for Z-Wave devices, any Zigbee items (Bulbs will not cycle).
-To Turn all On, select All button, then use any numbered button to turn All Z-Wave devices On/Off.
-Remote will stay in All On/Off mode until you press the Setup/Shift button once to return to normal.
-Remove Devices from the All On/Off feature:
-By factory default, all items are automatically added to the All On/Off control, to delete a device from the All On/Off feature:
-Press Delete once (Red Flash), Press All once (Green Flash).
-Press the assigned button of the item you want Removed from the All On/Off Feature (green flashes twice).
-Add Devices from the All On/Off feature:
-By factory default, all items are automatically added to the All On/Off control, to add a device back to the All On/Off feature:
-Press Add once (Red Flash), Press All once (Green Flash).
-Press the assigned button of the item you want Added back to the All On/Off Feature (green flashes twice).
GE 45600 REMOTE - FULL DUPLICATE/CLONE (MAKE A COPY OF A REMOTE)
-If you want a true duplicate remote, ensure you clear/reset the new one prior to transfer, else you will may retain any old devices already stored in the new remote. Prior to transfer, Reset/Clear remote by completing the following:
-New Remote into Receive Mode:
-Type 967, flashes green rapidly while waiting and during transfer (will flash red if it times out).
-Original/Old (Functional) Remote into Send Mode:
-Type 9661, flashes green rapidly while waiting and during transfer (will flash red if it times out).
- Complete when green flashes twice on Both Remotes.
GE 45600 REMOTE - TRANSFER NETWORK SETTINGS (COPY NET INFO WITH NO BUTTON/DEVICE DATA)
-Use this procedure if you want to add a remote by transferring the network info from another, but you do not want the button/device info transferred. This will render a new remote that is functional on the same network, but will not have any buttons/devices transferred from the original remote.
-If you want a blank remote, ensure you clear/reset the new one prior to transfer, else you will may retain any old devices already stored in the new remote. Prior to transfer, Reset/Clear remote by completing the following:
-Type 9662, flashes green rapidly while waiting and during transfer (will flash red if it times out).
GE 45600 REMOTE - PRIMARY CONTROLLER SHIFTS (NOT APPLICABLE WITH SMARTTHINGS)
-Codes 9681 & 9682 are for transferring full primary control from one remote to another (i.e. replacement). Since the SmartThings Hub is the primary controller, these functions have no purpose and will fail if attempted. These programing codes are only useful if you are using a GE 45600 Remote as a Stand-Alone Primary Controller, then you can transfer the same info similar to functions 9661 & 9662.
FACTORY RESET - ANY Z-WAVE DEVICE
-There is a set of Z-Wave Utilities on the App that offer some capabilities, find it under the Hub Setup screen (Options, Setup Gear, Select Hub, then ZWave Utilites, the Device Exclusion option may help you to reset a device.
-The GE45600 Remote is great tool if you are have a pairing issue to a Hub, this will force reset the device to its factory settings; by far, the remote is the most useful reset tool available.
-It seems like some manufactures may test a device at the factory and then forget to reset or unpair the device, thus the new device will block you from pairing it to a new network.
-Once a Z-Wave device is paired, it will not allow itself to be paired to another item unless you reset, but it you reset it you will have a dead device in you ST Hub/App.
-You should always remove all devices from the Hub via the App Things page prior to removing from your system, failure to do so will leave the device paired and a dead device listed on your Hub, you will then need to Force Remove the device from the ST Hub via the App and Factory reset the device per below (Note the Delete button is used below, not the Remove):
-Factory Reset a Device (Light/Switch) via a GE 45600 Remote:
-Press Delete (Red Blink), Press Light (flashes green rapidly).
-Press button on actual device, reset is complete when green stops flashing.
-Now you can reinstall the device per normal setup via the ST App.
