That is a video from the ST page. It was used as a setup guide for using Sonos with ST.
They have completely revamped the app interface since that time.
It used to look prettier
Version 2.06(1214) on my iPhone 6 and 2.07 build 202276 on my Android tablet.
That also wasn’t my video. Just a quick Google search to help the guy with the question about sonos
Hey which app are you using for your Sonos currently? I’m assuming at this point that in order to get the speaker to state custom messages (such as “Your clothes are now washed”) you need to use the approach @SergioDJ mentioned at the following link below which involves using the ST template “Speaker Notify with Sound”.
Those are the switch covers I use too. Here is my front door. Light switch for outside stays on, switch for inside can be changed. Outside stays on because there are three lights connected. Two by the car come on at sunset, off at sunrise. The one by the front door comes on with motion. So I don’t want that switch turned off. Both switches are GE 12722.
Awesome, thanks for the picture also! I have almost the same identical setup you do as well haha!
How about the screws? I heard you need to buy longer screws as some of the ones that come with the switch plates aren’t long enough?
True. They barely grab, so I need to replace them. I live a block away from HD though.
Do you have two of the 12722’s next to each other? I realized I had to clip the metal tabs on the front off so they could fit next to each other.
Nope, I replaced most of the switches to rockers way before I decided to take HA more seriously (most due to the upfront cost haha) whereas now it’s just slowely adding whatever device I want one after after.
Correct me if I’m wrong but the 12722’s are the zwave switches right? Don’t you need a neutral wire also connected to those since the electronics need that constant power flowing through to operate? I don’t have many neutral wires so I’d have to add one in, and since that’s not done in a lot of places unfortunately, it would be a bit more work than I wanted to sign up for so I just used basic rocker switches from HD, especially since I’m not an electrician but could still do it regardless though haha!
yes they do require a neutral.
