Xiaomi integration
Thank you Bro. It was that easy. Chatgpt and Deepseek gave a lot of diferent yaml codes. I actiilly didnot have a hope anymore for this integration. Thank you very much! The delay is 3sec. But it is not a big deal in my case. Only unsolved issue is with my xiaomi ai ir speker. It is plagged tonpower, its clocks are are showing time, its bluetooth mesh is working, i can find it on my phones Bluetooth, it is online on mihome application but still it appears offline in Smartthings and Home Assistant. Most probably because it uses chinese servers
Glad you got it working, I am also a new bee with HA.
I managed to bring wyze cams from homa assistent but they are showing as matter switch. Do you have any ideo how to update them to work as camera?
So far the Matter standard doesn’t include cameras. Maybe they will be added next year.
I have switched to the Xiaomi integration that is maintained by Xiaomi devs and it gives me local LAN control for my Xiaomi devices. You should give it a try. GitHub - XiaoMi/ha_xiaomi_home: Xiaomi Home Integration for Home Assistant
Edit: …..and it is substantially faster reaction times as opposed to the cloud integration.
Yes i also tried this, but now i have deley only 2 seconds including time for reley and lighting up of led strips, so i am okey woth 2 seconds. But for aading door magnetic sensors directly to ble monitoring i qas requested binding code not token. And i was not able to obtain biding code. They using some kind of encription. If you have any available information please share
Sorry, I don’t have any BLE devices or experience. Did you look at this: GitHub - PiotrMachowski/Xiaomi-cloud-tokens-extractor: This tool/script retrieves tokens for all devices connected to Xiaomi cloud and encryption keys for BLE devices.
and this: Xiaomi BLE - Home Assistant
I’ve been using a windows based token extractor and no bind keys was visible in there. This time I tried HA based token extractor, it took some time to figur out how to view catcha in HA but magic happened. I was able to see all bindkey for devices that are connected to getaways mesh, i even added 1 twmperature and humidity sensor directly using chip 8$ usb Bluetooth dongle. Thanks everybody for the help.
Glad you got sorted. HA is a bit of a learning curve but once you get it, it is very powerful
With a 0 knowladge of coding, linux all this ssh terminals I can say i am doing well :grin:
