Hello,
Is it possible to connect the Xiaomi Gateway to Smartthings to trigger the night light as well as use the siren? Here’s the Xiaomi Gateway that I have: https://www.gearbest.com/living-appliances/pp_344667.html
Thanks,
Josh
Hello,
Thanks,
Josh
unfortunately not
@Automated_House that’s unfortunate, thank you for the update. Is it because the gateway is a hub and can’t be connected with Smartthings?
yeah, something like that.
Would you be able to tell me if I could connect sensors door contacts to the gatway to use the security feature awith the siren and run the sensors and contacts to operate lighting through smarthings also
