I’ve just noticed that when an event is fired, SmartThings is now sending the wrong “eventTime” in the JSON payload. It’s always sending “1970-01-01T00:00:00Z”.
Has anyone seen this? I’m seeing this on two SmartThings Multipurpose sensors on the same hub.
Yes, we are receiving the same eventTime on several devices. It started around 1:11 PM CST on Oct, 26. We have tried to power cycle the hub at each location, but the eventTime is still coming in as “1970-01-01T00:00:00Z”.
I saw it had automatically fixed itself, and now it’s back to the wrong bheaviour. Power cycling had no effect.
As a workaround I ended up just changing my code to look at the time the request came in, instead of relying on the JSON content for the timestamp. Not ideal… but suitable for now.
I know it’s been a while on this post, but I just got through writing my first SmartApp and I am also seing this problem. Is this a known thing, or am I doing something wrong?
Hey @josep1972, no you’re not doing anything wrong.
In fact it’s getting even worst.
Until yesterday, all our SmartThings events had an eventTime of “1970-01-01T00:00:00Z” which is the first EPOCH time.
But, since yesterday, without any warning, the connections are not supposedly sending the correct eventTime.
Unfortunately, this only works for some sensors (like the Fibaro door ones and the samsungs power plugs), but now we have some sensors (like the Aeotec multi sensor or Aoetec door sensors) that are sending dates like “1970-01-20T07:00:17Z” or “1970-01-20T07:01:33Z” looks close but it’s not the first EPOCH time.
