When the list value is not changed, there is message "A network or server error occurred. Try again later"
I’m making edge driver.
the capability is list type.
When the value is changed. It works well.
But not select any value or select same value.
then spinner displays for a while and there is a message.
“A network or server error occurred. Try again later”
handler
local newdevice = command.args.device
device:emit_event(capabilities[command.capability].device(newdevice))
and it is a custom capability
I found a solution after I wrote.
state_change
This field allows you to explicitly inform the platform that an event is a state change. The most common use case for this is button events. Because the attribute value for a button press is always the same value, if you press a button twice in a row, regardless of the time between presses, the platform won’t see a change in value and thus would treat the event as not being a state change, and so the event would not be forwarded to subscriptions (rules, connected services, etc.) By specifying state_change = true you can force the event to be treated as a state change regardless of its relationship to the previous value. It is important to note that state_change = false is not guaranteed to be treated as not a state change, as a value different from the previous state value will always be treated as a state change regardless of this field.
local capabilities = require “st.capabilities” local event_state = capabilities.button.button.pushed({ state_change = true }) – or if an attribute doesn’t have enum values local event_state_2 = capabilities.button.button(“pushed”, { state_change = true })
