Alexa, add the lamp to the living room group." Organize your smart home devices into groups and control them all with one command. Just ask to create a group or add and remove devices from your smart home group.
Not exactly an exciting new feature, but can give you hopes on possibilities in the future.
I never thought of âgroupsâ like that before. Like I made a group called âAll Inside Lightsâ and one for âAll Exhaust Fansâ but for some reason never thought about making groups for rooms. Iâll have to play with it.
That and creating some routinesâŚfor some reason I just manually give it 3 or 4 commands in a row and they are usually the same things every night.
The nice things about groups based on rooms is if you have an Alexa Device in that room, you can say âAlexa turn off the lightsâ and she will turn off only the lights in that group with the Alexa device.
While Smartthings and Alexa both utilize the same gadgets and certainly are tightly interwoven, I treat them as separate systems in a way.
Smartthings is about automating processes within my home, while Alexa is about using my voice to control things within my home. As such, after a few months of using Alexa I deleted all my rooms in Smartthings. Because I found there was often a conflict, and the ânaturalâ thing is to use natural names with your voice.
Doing this makes your Alexa configuration much more flexible, while not diminishing automations in any fashion. And it really pays off when using an ecobee (or two, as I do) and various lighting systems like Hue⌠so when you do new discoveries of devices in Alexa or Hue or whatever, there are no conflicts that mess with your voice control.
I do have some rooms defined in Webcore, but that operates strictly for automations and is not accidentally callable via Alexa.
Edit: on thinking a bit, perhaps I was tagged because in the past I said we should be able to use voice to build rules? This would be the start of that, wouldnât itâŚ
âAlexa, how do I create a Routine for Echo Buttons?â With Routines for Echo Buttons, control your smart home devices, music, and more, with the push of an Echo Button.
If you have a group that includes an Amazon Echo, you can now set a preferred/default speaker for music playback. For me, my choices are Sonos speakers or Multi-room music groups. You set the preferred speaker by going into the particular group and scrolling to the bottom.
Yes, for example; I have Sonos 5.1 and an Echo dot in the same room. If I wanted to play Spotify on Sonos I would have to specify the name of the device I wanted it to play on before ending the command, if I did not music would play on the Echo Dot itself. Now I would just say play Spotify and it would automatically play on the intended device you setup.
Not sure when this took effect, but if you have multiple temperature sensors in a group when asking Alexa the temperature of that group/room, Alexa will respond with the average temperature of your devices.
Amazon didnât announce the feature that I know of, I just happen to come across it while in the app.I tried it today, but no music played on anything until I specified the speaker, so maybe there putting some final touches on it before itâs released to everyone.
So far, Alexa has evolved to include alot of goodies especially the ability to invoke Alexa actions and responses programmatically. I am waiting on the ability to define more device types such as fan, heater, etc. I have Echo devices in most rooms and some rooms I have 2 or 3 (Tablet, Echo and FireTV for example). Would love to be able to just say, âAlexa, turn on the heaterââŚ
The groups are SUPER cool!
Alexa, whatâs the temperature in here?
Alexa, turn off the lights.
Alexa, watch Netflix.
Alexa, pause, play, etc.
Alexa, play my music, plays on everything downstairs!
