joelw135
(Joel W)
January 15, 2023, 10:39pm
1
I have a ST Multi sensor and a Monoprice 4 in 1, need an Edge driver. Is there one?
mlchelp
(michael watson)
January 15, 2023, 11:01pm
2
@joelw135 ST Multi sensor works perfectly with Zigbee Contact MC. Mariano’s channel invite below.
Build a smart home to support all your big moments. With SmartThings, your home becomes a connected space that makes your life simpler, safer, and more entertaining.
mrfitz98
(Michael Fitzgerald)
January 15, 2023, 11:12pm
3
I’m using my monoprice 4-1 with Mariano’s Z-Wave Sensor and Child Thermostat Mc driver. Works great.
I am using mine with @philh30 “Z-wave sensor PH” driver. It gives you access to all the settings.
joelw135
(Joel W)
January 15, 2023, 11:43pm
5
I have no luck with these drivers. The Multi Sensor shows no Humidity. The 4 in 1 doesn’t even show as an available driver for the device. Any ideas?
This is what it looks like using @philh30 driver:
mlchelp
(michael watson)
January 16, 2023, 12:10am
7
Wow I didnt even notice that, I only use these for vibration detection. Sorry, that is the only driver I was able to find. You would think that Smartthings would have a driver to support it! If you ask Mariano im sure he will add it for you. Post a message to him in.
Updated list of Edge Drivers published in my channel (Feb/2)
(New RELEASE) New Edge Drive Zigbee Light Multifunction Mc:
This Driver has all the functions of the Zigbee Level ColorTemp Bulb Mc driver, which it replaces and will not be updated any more.
Added Color Control Capability with profiles for RGB and RGBW with 2700k-6500k Color temperature.
Thanks to the suggestion and collaboration to do the tests for @milandjurovic71
Works with lights, led strips with profiles :
Switch & Level
Switch, Level & ColorTemperature
Switch, Level, RGB, RGBW, RGBCCT, CCT
Could work with zigbee single dimmers, but not tested
Link to the Zigbee Light Multifunction Mc Driver Thread
Included Devices : See this link
https://community.smartthings.com/t/new-release-beta-edge-driver-zigbee-light-…
joelw135
(Joel W)
January 16, 2023, 3:54pm
10
I installed the driver Z-Wave sensor (PH) but it hasn’t shown the temp or humidity or battery. How do I get it to update, or did I pick the wrong driver?
When conditions change they should update. Put it in the freezer to force some changes. Battery some times takes 12 Hrs. to update.
