Device Handler for WeMo Bulbs which uses the latest SmartThings UI.
* WeMo Direct LED Bulbs
* Copyright 2014 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Thanks to Chad Monroe @cmonroe and Patrick Stuart @pstuart
//DEPRECATED - Using the generic DTH for this device. Users need to be moved before deleting this DTH
metadata {
definition (name: "WeMo Bulb", namespace: "smartthings", author: "SmartThings", ocfDeviceType: "oic.d.light") {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Sensor"
capability "Switch"
capability "Switch Level"
// simulator metadata
simulator {
// status messages
status "on": "on/off: 1"
status "off": "on/off: 0"
// reply messages
reply "zcl on-off on": "on/off: 1"
reply "zcl on-off off": "on/off: 0"
// UI tile definitions
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'Turning On', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
attributeState "turningOff", label:'Turning Off', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel"
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch", "refresh"])
// Parse incoming device messages to generate events
log.trace description
if (description?.startsWith("catchall:")) {
//def msg = zigbee.parse(description)
//log.trace msg
//log.trace "data: $msg.data"
if(description?.endsWith("0100"))
def result = createEvent(name: "switch", value: "on")
log.debug "Parse returned ${result?.descriptionText}"
return result
if(description?.endsWith("0000"))
def result = createEvent(name: "switch", value: "off")
return result
if (description?.startsWith("read attr")) {
log.debug description[-2..-1]
def i = Math.round(convertHexToInt(description[-2..-1]) / 256 * 100 )
sendEvent( name: "level", value: i )
def on() {
log.debug "on()"
sendEvent(name: "switch", value: "on")
"st cmd 0x${device.deviceNetworkId} 1 6 1 {}"
def off() {
log.debug "off()"
sendEvent(name: "switch", value: "off")
"st cmd 0x${device.deviceNetworkId} 1 6 0 {}"
def refresh() {
"st rattr 0x${device.deviceNetworkId} 1 6 0", "delay 500",
"st rattr 0x${device.deviceNetworkId} 1 8 0"
def setLevel(value) {
log.trace "setLevel($value)"
def cmds = []
if (value == 0) {
cmds << "st cmd 0x${device.deviceNetworkId} 1 8 0 {0000 0000}"
else if (device.latestValue("switch") == "off") {
sendEvent(name: "level", value: value)
def level = hexString(Math.round(value * 255/100))
cmds << "st cmd 0x${device.deviceNetworkId} 1 8 4 {${level} 0000}"
//log.debug cmds
cmds
def configure() {
log.debug "Configuring Reporting and Bindings."
def configCmds = [
//Switch Reporting
"zcl global send-me-a-report 6 0 0x10 0 3600 {01}", "delay 500",
"send 0x${device.deviceNetworkId} 1 1", "delay 1000",
//Level Control Reporting
"zcl global send-me-a-report 8 0 0x20 5 3600 {0010}", "delay 200",
"send 0x${device.deviceNetworkId} 1 1", "delay 1500",
"zdo bind 0x${device.deviceNetworkId} 1 1 6 {${device.zigbeeId}} {}", "delay 1000",
"zdo bind 0x${device.deviceNetworkId} 1 1 8 {${device.zigbeeId}} {}", "delay 500",
return configCmds + refresh() // send refresh cmds as part of config
private hex(value, width=2) {
def s = new BigInteger(Math.round(value).toString()).toString(16)
while (s.size() < width) {
s = "0" + s
s
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
