Background & Goal
Goal (very clear)
The goal is to build a background-only SmartThings integration that:
Subscribes to existing devices in a personal SmartThings account
Receives real-time device events (push-based, not polling)
Sends those events to an external endpoint (Google Apps Script → Spreadsheet / Cloudflare / ntfy, etc.)
No UI required
No Home Assistant
No Raspberry Pi / local server
Hosting platform: Google Apps Script (HTTPS Web App)
In short:
We want SmartThings to push device events to a webhook hosted on Google Apps Script, without requiring user interaction or UI after initial setup.
Technology Stack Used
Platform: Samsung SmartThings
Webhook Host: Google Apps Script (deployed as Web App, HTTPS)
No local hardware
No polling (polling was intentionally avoided due to missed events and quota concerns)
Initial Working Pieces (What DID work)
1. Webhook connectivity
Google Apps Script Web App is publicly accessible over HTTPS
SmartThings successfully calls:
PING -
CONFIRMATION
Confirmation lifecycle was completed successfully by calling the provided
confirmationUrl
2. Lifecycle handling
The Apps Script correctly responds to:
PING -
CONFIRMATION -
CONFIGURATION -
UNINSTALL
This proves:
HTTPS
TLS
Endpoint reachability
JSON parsing
Response formatting
All are correct.
Original Approach Attempted
Project creation path used:
Developer Center → Create Project → Automation for the SmartThings App → Webhook Endpoint
This seemed correct initially because:
It allows a webhook
It does not require AWS Lambda
It appears to be the modern replacement for classic SmartApps
Where the Problem Starts
Observed behavior in logs:
Only these lifecycles are ever received:
CONFIGURATION
CONFIGURATION
CONFIGURATION
UNINSTALL
Never received:
INSTALL
Why INSTALL is critical
Device subscriptions can only be created during
INSTALL -
The
INSTALLlifecycle provides:-
installedAppId -
authToken(scoped token required for subscriptions)
Without
INSTALL, all subscription attempts result in 403 Forbidden
This was verified repeatedly.
SmartThings Mobile App Behavior
App appears under Smart Apps (Developer Mode enabled)
Tapping the app always shows:
“There was a problem connecting. Try again.”
Each tap results in another
CONFIGURATIONlifecycle -
Installation never completes
There is no visible “Install” or “Done” path
Root Cause (Key Insight)
After extensive debugging and lifecycle verification, the core issue became clear:
Automation SmartApps cannot be installed headlessly
Important platform behavior:
Automation SmartApps are UI-driven by design
They expect:
Valid automation context (triggers, actions, routines)
A configuration flow that SmartThings can complete
A “background-only” automation is silently rejected
When SmartThings cannot finalize configuration, it:
Loops
CONFIGURATION -
Never fires
INSTALL -
Shows a generic “problem connecting” error in the app
This behavior cannot be fixed by code alone.
Why this is confusing (and a trap)
The term “SmartApp” is used in multiple places
The Automation Webhook path looks like the old Webhook SmartApp
But functionally it is not equivalent
Important distinction:
| Type | Purpose |
| Automation SmartApp | UI-driven routines & automations |
| Webhook SmartApp / Connector (classic) | Background integrations, subscriptions |
The Automation path cannot satisfy the “no UI, background-only” requirement.
What Was Tried (and Why It Failed)
Adding fake CONFIGURATION pages
Returning
complete: true -
Adding dummy sections
Ignoring UI and attempting subscriptions manually
Using PATs (403 errors confirmed)
Reinstalling multiple times
CLI & API inspection
All failed for the same reason:
INSTALL never fires
Environmental Constraints
No Home Assistant
No Raspberry Pi
No always-on server
Google Apps Script chosen intentionally for:
HTTPS
Zero infrastructure
Reliability
Easy logging
What We Believe Is Needed (Request for Guidance)
We are looking for official or supported guidance on one of the following:
Option A (Preferred)
A true Webhook SmartApp / Connector-style project that:
Can be hosted on Google Apps Script
Fires
INSTALL -
Supports device subscriptions
Does not require UI or automation routines
If this still exists in the new Developer Center, where exactly is it created?
Option B (Acceptable workaround)
A documented way to complete Automation SmartApp installation for:
Background-only apps
No triggers/actions
Subscription-only use cases
Option C (Confirmation)
If SmartThings no longer supports background webhook listeners without UI, we would like:
Explicit confirmation
Recommended alternative architecture (cloud relay, schema, etc.)
Final Ask (Very Clear)
Is it currently possible (in 2026) to create a background-only SmartThings webhook that subscribes to device events without UI, using a hosted HTTPS endpoint (e.g., Google Apps Script)?
If yes:
- Please point to the correct project type / workflow
If no:
- Please confirm this limitation so developers stop attempting an unsupported pattern
This summary reflects multiple days of structured debugging, not trial-and-error.
Any authoritative clarification from SmartThings staff or experienced partners would be hugely appreciated.
