No neutral at the fixture is very odd unless it’s a very old house using knob and tube wiring.
There are four basic options for the switchbox that doesn’t have a neutral.
Bring in an electrician and have them “fish up” a neutral from somewhere else on the circuit. This won’t work if you have knob and tube wiring, but otherwise it will.
use one of the Z wave switches that doesn’t require a neutral. However, this will probably only work with incandescent bulbs, GE used to make some of these switches, but they are hard to find now. Cooper still makes one.
See the following thread for some of the issues:
And specific model links:
Use a smart bulb and cover the existing switch with a battery-operated " smart switch cover". This is a “no wiring” solution.
use a Lutron Caseta switch and get indirect integration through IFTTT. The switch will work fine as a wall switch. Scheduling lights at specific times will work fine. Issuing an “all off” Comand should work fine. However, IFTTT does introduce additional lag which would be noticeable for things like having a motion sensor turn on the light.
So you do have options, just depends on which direction you want to go.
