The ecobee3 sensors cannot work with other thermostats, they use a proprietary protocol…
If you want to reproduce a similar configuration as the ecobee3, you can buy any z-wave or zigbee sensors with the thermostat of your choice (as long as it’s supported by ST such as the CT-100) and use the following smartapp:
The smartapp allows adjustments at the thermostat based on an average temp calculation from room’s sensors.
