Hello, Anyone here set up scraping of the html page from the older Envoy-C? (pill shaped, production monitoring only, software older than R3.9.xx) Mine is R3.7.26 and the .json pages are not there. It sounded like @chewie8han had the same version Envoy, ever get it working? The html pages are there with data, just different format to scrape from, not as simple as the nice .json format.
Iām using homeassistant, and the code there works for the .json pages on newer s/w Envoy-C and Envoy-S ( /api/v1/production, /production.json pages), as it sounds like you have working here also. I figure Iāll add to the home assistant envoy_reader code, to do the .html pages on the older s/w Envoy-C, if itās not available somewhere already.
Iām just using the current version of the DTH posted in the first post. Pollster refreshes the data every 15 minutes for me. I have no experience with homeassistant, so I canāt really help you there.
For some reason when I go to enter the setup data in the settings, a Red banner keeps popping up saying that i need to enter all required fields when trying to save even know they already are! Any thoughts?
FINALLY got things goingā¦
Looks like I have the M250 Inverters, based on the part number I saw in the Enlighten App detailsā¦
And my PV Modules appear to be the 315W Panels⦠(PV Module: REC315PE72 REC).
The numbers still seem to not align with the data I see in the Enlighten app�?
I also seem to be seeing a Java Timeout error when making queries to the DBā¦
10:53:57 AM: **error java.util.concurrent.TimeoutException**: Execution time exceeded 20 app execution seconds: 521964122406836 @line 520 (dataCallback)
10:53:37 AM: trace Querying DB for yesterday's dataā¦
10:53:37 AM: debug Solar - new data: [wattHoursLifetime:41078, wattHoursSevenDays:39739, wattHoursToday:21154, wattsNow:7233]
10:53:37 AM: debug Solar - requesting latest data from Envoy via JSON APIā¦
I seem to be seeing yesterday and todays data being the same also�?
Also, after further debugging of the code, I see what others have seen on the past, it SEEMS to be completely unable to save the STATE data⦠do PowerChange isnt working, as well as the graph dataā¦
Still working on TRYING to debug it⦠but still not working⦠Iām almost assuming it is related to the timeout trying to get historical data, but not sureā¦
Iāve actually gone through and commented every block like this in the code⦠(thereās 4 of themā¦)
// 2019-07-11 - KTK - This call is causing a timeout and apparently an exit!
//while ((newValues = device.statesBetween("energy", startOfToday, energyData.last().date, [max: 288])).size()) {
// energyData += newValues
This gets rid of the Java errors everybody sees, and then immediately my graph started populatingā¦
Additionally, my powerChange and other STATE values were finally gettign properly stored/updatedā¦
Iāll have to dig through this more to understand what it removes from functionalityā¦
but I seem to have a workign APPā¦
NOW, what I need to try and figure out is what that Power Reading is⦠(wattHoursToday, as I cant get that number to match anything in the Elighten data or even if I connect to the Enphase Envoy directly with the toolkit and look at live data�?? SO what is that???
It LOOKS like this thread is basically dead⦠kind of a bummerā¦
Those lines are trying to read the db (event history) to populate the history for the graphs.
On ST, these commands are notorious for timing out. commenting them out is likely the best thing to do as they wonāt run much once the history is populated.
I thought I downloaded the latest code just a couple weeks ago⦠but it kept repeatedly sending those errors, causing the function to drop out and nothing would get savedā¦
Have you updated the code in the last week or two?
I also cant get my install date, so seems like in this situation, it might be better to just add a config option to enable entering a date and use that if you cant get it from the systemā¦
My Envoy pops the user/password prompt when trying /production urlā¦
Also⦠for the wattHoursToday value⦠what is that? It certainly doesnāt seem to match what comes back from my Enlighten monitoring data⦠(or is that part of a calculation somewhere and why we need to enter the # of panels, PV Type and Panel max value? (My Panels have a NOMINAL output of 315⦠not sure what the MAX isā¦)
Seems like you are running a FW on your Envoy that isnāt really supported by this DTH, Iāve never seen user/pass request for the production page.
That is the current power (in Wh) produced so far for the current date. The Enlighten website will show those values with a delay with respect to the Envoy and it adds some filtering/post-processing which will make the values not fully agree at the end of the day. I prefer using the raw data as reported by the Envoyā¦
Did this stuff ever get incorporated into the code, and I somehow got an older version?? This would GREAT to be able to have and add to action tiles dashboardsā¦`
Mines was working fine for the past couple years until now! A few days ago, smartthings was showing the device as " unavailable" so I uninstalled then reinstalled everything. Readings throughout the day seem to be accurate, as well as lifetime and last 7 day production, but āyesterdayā seems to be incorrect pretty frequently. Itās been about 4 days and still NOTHING showing up on the graph. Any ideas? I vaguely remember changing something in the code before (when it worked) but I could be wrong.
Iām more than interested in making updates, but would like to find the consumption branchā¦
Actually, Iād love to figure out how to combine them into a single app/dthā¦
Also still interested in why the energy generated is so far off from what I see in Enlighten, and even pvoutput data⦠20kWH difference today seems like a big differenceā¦
