I’m trying to write my first Device Handler, and i’m following the quickstart from the docs, but no matter what I try i just get an “Unknown” tile in the simulator. I’m just trying my own Hello World for goodness sake!
I was using just templates from simple switches or dimmers assuming they would work in the simulator.
tgauchat
2
Paste the code or GitHub / Gist link and myself or someone is likely to spot a possible syntax error or SmartThings quirk.
Be sure to surround pasted code here using the </> format button.
Hi there, I’m having exactly the same problem as instanttim - using any of the pre-made device handlers seems to give me a device handler that just shows (and seems completely stuck on) the grey ‘unknown’ tile in the simulator.
To reproduce:
Go to ‘My Device Handlers’
Click ‘Create New Device Handler’
Click the ‘From Template’ tab
Pick any template e.g ‘Z-Wave switch’
Click ‘Save’
In right hand column, select location and click ‘Set Location’
Select virtual device and click ‘Install’
Get grey Unknown panel as per instanttim’s screengrab above
Clicking on/off buttons etc below the grey unknown panel seem to have no effect (although log messages are getting produced)
It’s possible I’ve misunderstood how this is supposed to work, but it seems a bit broken to me. Has anyone successfully used this in the past?
Richard
tgauchat
6
Yes … I do recall having more success with the IDE Simulator in the past. I was working on some reasonable modifications to a DTH this week and the Simulator exhibited the behavior you describe.
I suggest contacting: Support@SmartThings.com for the record as I believe this is a bug.
But @Dianoga might know more (or @slagle, @jody.albritton).
I’m seeing the same thing. I have tried to make several different Device handlers from templates and all of them are giving me the “UNKNOWN” tile. Including device templates for Smartthing devices.
I just got an email back from support stating that this is a know issue that they are working on.
No ETA. At least a know it’s not just me and I’m not crazy or doing something wrong.
