Tweak SmartSense Open/Close Sensor Handler For Longer Battery Life?
I have no need for my door sensor to check in for temp. Its nice to have but can I tweak it so it checks in less? I see some codes that look to be pull times but Im not sure what to change. Here is the handler im working with…
  • SmartSense Open/Closed Sensor
  • Copyright 2014 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
import physicalgraph.zigbee.clusters.iaszone.ZoneStatus
metadata {
definition(name: “SmartSense Open/Closed Sensor”, namespace: “smartthings”, author: “SmartThings”, runLocally: true, minHubCoreVersion: ‘000.017.0012’, executeCommandsLocally: false) {
capability “Battery”
capability “Configuration”
capability “Contact Sensor”
capability “Refresh”
capability “Temperature Measurement”
capability “Health Check”
capability “Sensor”
	command "enrollResponse"
	fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05", outClusters: "0019", manufacturer: "CentraLite", model: "3300-S"
	fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05", outClusters: "0019", manufacturer: "CentraLite", model: "3300"
	fingerprint inClusters: "0000,0001,0003,0020,0402,0500,0B05", outClusters: "0019", manufacturer: "CentraLite", model: "3320-L", deviceJoinName: "Iris Contact Sensor"
	fingerprint inClusters: "0000,0001,0003,0020,0402,0500,0B05", outClusters: "0019", manufacturer: "CentraLite", model: "3323-G", deviceJoinName: "Centralite Micro Door Sensor"
	fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05", outClusters: "0019", manufacturer: "Visonic", model: "MCT-340 E", deviceJoinName: "Visonic Door/Window Sensor"
	fingerprint inClusters: "0000,0001,0003,0020,0402,0500,0B05", outClusters: "0019", manufacturer: "Ecolink", model: "4655BC0-R", deviceJoinName: "Ecolink Door/Window Sensor"
	fingerprint inClusters: "0000,0001,0003,0020,0402,0500,0B05,FC01,FC02", outClusters: "0003,0019", manufacturer: "iMagic by GreatStar", model: "1116-S", deviceJoinName: "Iris Contact Sensor"
simulator {
preferences {
	input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter \"-5\". If 3 degrees too cold, enter \"+3\".", displayDuringSetup: false, type: "paragraph", element: "paragraph"
	input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
tiles(scale: 2) {
	multiAttributeTile(name: "contact", type: "generic", width: 6, height: 4) {
		tileAttribute("device.contact", key: "PRIMARY_CONTROL") {
			attributeState "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#e86d13"
			attributeState "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#00A0DC"
	valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
		state "temperature", label: '${currentValue}°',
				backgroundColors: [
						[value: 31, color: "#153591"],
						[value: 44, color: "#1e9cbb"],
						[value: 59, color: "#90d2a7"],
						[value: 74, color: "#44b621"],
						[value: 84, color: "#f1d801"],
						[value: 95, color: "#d04e00"],
						[value: 96, color: "#bc2323"]
	valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
		state "battery", label: '${currentValue}% battery', unit: ""
	standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
		state "default", action: "refresh.refresh", icon: "st.secondary.refresh"
	main(["contact", "temperature"])
	details(["contact", "temperature", "battery", "refresh"])
log.debug “description: $description”
Map map = zigbee.getEvent(description)
if (!map) {
	if (description?.startsWith('zone status') || description?.startsWith('zone report')) {
		map = parseIasMessage(description)
	} else {
		Map descMap = zigbee.parseDescriptionAsMap(description)
		if (descMap?.clusterInt == 0x0001 && descMap.commandInt != 0x07 && descMap?.value) {
			map = getBatteryResult(Integer.parseInt(descMap.value, 16))
		} else if (descMap?.clusterInt == 0x0500 && descMap.attrInt == 0x0002) {
			def zs = new ZoneStatus(zigbee.convertToInt(descMap.value, 16))
			map = getContactResult(zs.isAlarm1Set() ? "open" : "closed")
		} else if (descMap?.clusterInt == zigbee.IAS_ZONE_CLUSTER && descMap.commandInt == 0x07) {
			if (descMap.data[0] == "00") {
				log.debug "IAS ZONE REPORTING CONFIG RESPONSE: $descMap"
				sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
			} else {
				log.warn "IAS ZONE REPORTING CONFIG FAILED- error code: ${descMap.data[0]}"
} else if (map.name == "temperature") {
	if (tempOffset) {
		map.value = (int) map.value + (int) tempOffset
	map.descriptionText = temperatureScale == 'C' ? '{{ device.displayName }} was {{ value }}°C' : '{{ device.displayName }} was {{ value }}°F'
	map.translatable = true
log.debug "Parse returned $map"
def result = map ? createEvent(map) : [:]
if (description?.startsWith('enroll request')) {
	List cmds = zigbee.enrollResponse()
	log.debug "enroll response: ${cmds}"
	result = cmds?.collect { new physicalgraph.device.HubAction(it) }
return result
private Map parseIasMessage(String description) {
ZoneStatus zs = zigbee.parseZoneStatus(description)
return zs.isAlarm1Set() ? getContactResult(‘open’) : getContactResult(‘closed’)
private Map getBatteryResult(rawValue) {
log.debug ‘Battery’
def linkText = getLinkText(device)
def result = [:]
def volts = rawValue / 10
if (!(rawValue == 0 || rawValue == 255)) {
	def minVolts = 2.1
	def maxVolts = 3.0
	def pct = (volts - minVolts) / (maxVolts - minVolts)
	def roundedPct = Math.round(pct * 100)
	if (roundedPct <= 0)
		roundedPct = 1
	result.value = Math.min(100, roundedPct)
	result.descriptionText = "${linkText} battery was ${result.value}%"
	result.name = 'battery'
return result
private Map getContactResult(value) {
log.debug ‘Contact Status’
def descriptionText = “{linkText} was {value == ‘open’ ? ‘opened’ : ‘closed’}”
return [
value : value,
descriptionText: descriptionText
  • PING is used by Device-Watch in attempt to reach the Device
    def ping() {
    zigbee.readAttribute(zigbee.IAS_ZONE_CLUSTER, zigbee.ATTRIBUTE_IAS_ZONE_STATUS)
def refresh() {
log.debug “Refreshing Temperature and Battery”
def refreshCmds = zigbee.readAttribute(zigbee.TEMPERATURE_MEASUREMENT_CLUSTER, 0x0000) +
zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020)
return refreshCmds + zigbee.enrollResponse()
def configure() {
// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
// enrolls with default periodic reporting until newer 5 min interval is confirmed
sendEvent(name: “checkInterval”, value: 2 * 60 * 60 + 1 * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID, offlinePingable: “1”])
log.debug "Configuring Reporting, IAS CIE, and Bindings."
def cmds = refresh() + zigbee.iasZoneConfig(30, 60 * 5) + zigbee.batteryConfig() + zigbee.temperatureConfig(30, 60 * 30)
if(getDataValue("manufacturer") == "Ecolink") {
	cmds += configureEcolink()
// temperature minReportTime 30 seconds, maxReportTime 5 min. Reporting interval if no activity
// battery minReport 30 seconds, maxReportTime 6 hrs by default
return cmds
private configureEcolink() {
sendEvent(name: “checkInterval”, value: 60 * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID])
def enrollCmds = zigbee.writeAttribute(0x0020, 0x0000, 0x23, 0x00001C20) + zigbee.command(0x0020, 0x03, "0200") +
		zigbee.writeAttribute(0x0020, 0x0003, 0x21, 0x0028) + zigbee.command(0x0020, 0x02, "B1040000")
return zigbee.addBinding(0x0020) + refresh() + enrollCmds
Does anyone know how to tweak the code or help me understand what I need to change to make the sensor check in less?
When posting code please use the Preformatted text tag. Otherwise its very hard to read. As to your question I believe its more in the firmware then in the DTH. I.e. I don’t think you can do much about it.
