Hi everyone!!!
Just wanted to know if its possible for my pc to switch on the moment i get closer for smartthings to turn it on, i dont mind doing it manually with Bixby, wanted to know if its possible to turn off/on my pc with smart things??
Hi everyone!!!
What type of PC do you have and what operating system does it use?
do you have a SmartThings/Aeotec hub, and if so, which model?
In some configurations, it will be possible to turn the PC on and off using what is called “wake on LAN“ .
But when it comes to automatically turning it on as you approach the PC, that’s yet a separate step. You might need an occupancy sensor to indicate when you have entered the area.
So it may be doable, it may not, it just depends on the details.
i have a gaming pc that i use the lan for connection
Gigagbyte B150M
Geforce 1070ti
16 GB ram
I5-6500 3.20Ghz
Windows 10 pro
i dont have the hub but i have the app installed in the pc
As for when i approach the pc isnt that what bixby routines come in because it can switch on my tv so i was wondering if it can do the dame when it comes to my pc
And how do i do it with wake on lan?
There are devices that you can plug into a PCIe port and can be controlled via the Tuya app/cloud:
https://aliexpress.com/item/1005002776442806.html
Click through the images to find a feature matrix of the different models.
You can connect Tuya and SmartThings and if you are lucky, the device will show up - maybe as a simple switch. You’d be the first to find out if it works, but these devices are surprisingly cheap.
In SmartThings you could create a routine that turns the switch on when a (motion/presence) sensor detects you.
Edit: and if they won’t integrate in ST via cloud-to-cloud connection, you’d still be able to turn your PC on with the Tuya app or voice control.
if you’ve ever even considered to buy a hub, this has been working excellently. It has also ability to shutdown your PC and give you info if your PC is on or off.
I’ll check the ports you sent, i thought maybe theres a possible way to that without any additions because aliexpress tends to be aheadache in my country they take ages to arrive or not arrive at all, because i saw a youtube video where this peraon switches on the pc with google assistant so i thought amybe i can be able to do it with bixby v
Do you personally use it?
I´ve been using it on daily basis with multiple PCs since the driver was released. It works like a champ and you can make some pretty cool routines with it ![]()
