Just curious if there is an app for this.
the trigger is the same switch state where it need to be ON all the time, but sometimes it need to be turned OFF. I need the app to turn it back ON automatically after x minutes when the switch mode change to OFF.
Is there such an apps for this ?
I have try to search, but people tend use the OFF action, rather than ON action.
my usage is simply as turn back on my fish tank filter power after turn the switch off e.g 15 minutes due to feeding time.
thanks.
i sometimes do this not on scheduled time, could be 3pm or 7pm depend on when i need to trigger this.
the best approach is to switch off (manually or through apps) and let the automation turn it back on after sometime.
If you don’t know how to create a virtual switch:
All of that said, I personally wouldn’t use SmartThings to control anything involving an aquarium which might harm the fish if it didn’t work correctly. I just don’t find the system reliable enough. I do use it for convenience cases, but not for health and safety, even for pets.
CoRE hasn’t been renamed.
You can set up a very simple rule using it to do what you require and then not worry about setting up a virtual Switch and then set up a rule for the virtual Switch.
But we all have different approaches and there probably isn’t a right or a wrong way just personal preference.
Spark Core is third-party cloud with a hardware piece. So is particle.Io
But the “CoRE” that people will recommend on this forum for rules management is a smartapp (software only) written for the SmartThings platform by community members here. CoRE = Community’s own Rules Engine.
Thanks JDRoberts … the Virtual Switch Approach work out perfectly. it took 3 smartapps to do this.
Let’s see how well this work out and closely monitor the switch state for sometime.
I have a minimote that I use to control my fishtank filter (2) and lights (2). I have button 1 programmed to turn off filter for X minutes then turn it back on. I used Rule Machine for that but it’s probably time to migrate to CoRE.
The other buttons I have programmed to turn OFF/ON the filters on button hold.
I would create a simulated (virtual) switch in the IDE, then create an IFTTT recipe that then flips that switch based of whatever trigger you wanted (an email received, facebook post, alexa phrase, whatever…)
Then use Smart lighting to turn off (or on) when your simulated switch is toggled for a time.
Hi Folks - I have no coding ability - wondering if anyone can fix the code here (Turn off Appliance Module for 30 minutes, then turn back on automatically) to make this request work. That smartapp won’t turn on the device after X minutes off. Looked everywhere and can find a tonne of off smartapps that do similar for things to go to the off state- just no back ON apps? There are a few folks like me been looking for such an app. Any help would be greatly appreciated
Thanks bobbles - I did look at Smart Lighting but it would require the unit to be turned off and then back on at a specific time. What I am seeking is if the switch somehow gets turned off at any time, after X minutes it will get turned back on. It is a failsafe for folks like me using Smartthings for aquarium functions (yes I know it is always risky to use Smartthings for critical functions) - that is way folks like me looking for a bit of protection in the form of this failsafe.
