Another small problem I had has been solved. When I turn off the light at the switch, I don’t want my motion sensor just turning it back on. I wrote this app so that it won’t turn on automatically for however many minutes after I turn it off. I currently have it set for one minute.
* Turn on with motion unless turned off
* Copyright 2015 Eric Roberts
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Turn on with motion unless turned off",
namespace: "baldeagle072",
author: "Eric Roberts",
description: "Any motion detected will turn the lights on unless the switch has been manually switched off recently.",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Devices") {
input "motion", "capability.motionSensor", title: "Motion Sensor", multiple: false
input "lights", "capability.switch", title: "Lights to turn on", multiple: true
section("Preferences") {
paragraph "If you turn off this light, the motion sensor will not turn on the lights for the specified minutes"
input "switchLight", "capability.switch", title: "Switch", multiple: false
input "minutes", "number", title: "Minutes"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(motion, "motion", motionHandler)
subscribe(switchLight, "switch", switchHandler)
state.enabled = true
state.runOff = true
def motionHandler(evt) {
log.debug "Motion Handler - Evt value: ${evt.value}"
if (evt.value == "active") {
if (state.enabled) {
log.debug("Turning on lights")
lights?.on()
} else {
log.debug("Motion is disabled - not turning on lights")
def switchHandler(evt) {
log.debug "Switch Handler - Evt value: ${evt.value}, isPhysical: ${evt.isPhysical()}"
if (evt.value == "off" && evt.isPhysical()) {
log.debug "Motion disabled"
state.enabled = false
def runInMins = minutes * 60
runIn(runInMins, enable)
def enable() {
log.debug "Motion enabled"
