Hi guys, I am running a hydroponic system that utilizes a pump to circulate nutrient solution. I would like an App like dry the wet spot to turn the pump OFF in case of a leak. Is there a way I could modify the app to do that? Thanks!
greg
(Greg)
December 7, 2015, 8:38pm
2
you could modify the app.
but the easiest solution would be to just use Rule Machine and make a trigger
Rule Machine is no longer available.
Yeah that looks like it’ll work. Handy for other stuff too, Thanks!
Lojack
(Community Journeyman)
January 29, 2016, 4:34am
4
I love Rule Machine, but this will do it also:
* Leak Stopper
* Copyright 2016 Louis Jackson
* Version 1.0.1 31 Jan 2016
* Version History
* 1.0.2 22 Dec 2016 Added Sonos speaker support by Lou Jackson
* 1.0.1 31 Jan 2016 Added version number to the bottom of the input screen
* 1.0.0 28 Jan 2016 Added to GitHub
* 1.0.0 27 Jan 2016 Creation :-)
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
This file has been truncated. show original
Enjoy!
