Trend setter
Trying to set up trend setter, but having troubles. when i try to add the codes to my device handlers and smartapps they error out. I did set my multiple light bulbs in smart lighting but for some reason when you turn on the master bulb the dim level is always at 0.
Best place to ask your questions is in the Trend Setter thread, that way the developer is alerted to your post…
So, did you get errors for the device handlers when you tried to add them? There are 6 device handlers that needed to be added.
missed a step in the process. works great now.
