toXml missing
Is the xml2lua.toXml method not supported? I am getting a nil for that symbol… Is there an alternative way?
Would xml2lua.printable() or xml2lua.toString() work for your needs? You could add any top level XML decoration needed yourself.
Of course I could code anything I need myself (or even just cut and paste from xml2lua codebase), but I was wondering if xml2lua’s built in functionality of converting a table to xml was available somehow as it would be weird to allow to parse xml but not output it – It does seem to have parsing xml into a table, but not the reverse of converting a table back to xml.
The two functions mentioned only print tables to text and do not convert to xml
Hi!
Following up on this question. The engineering team already made the report to update xml2lua to a greater version.
Just as a heads-up, this can take some time. We’ll let you know when we get an update.
