I hope you can help me because I’ve spend a few days on this and i’m getting nowhere.
I’ve copied an example from SmartThings documentation to allow the user to select a list of modes (required to detect change of mode and not which mode this SmartApp runs in):
input(“modes”, “mode”, title: “Which mode(s)”, multiple: true, require: true)
When testing using the IDE Simlutor I can select the modes that I require but the modes variable is always == null.
So I published the app for me and ran it on my mobile phone. Using notifications (is there a better way to record logs when debugging on mobile?) modes correctly shows as [Night, Home] but then following code fails…
modes.any {it.name == evt.value}
or if I change it to…
modes?.find{it.name == evt.value}
Both examples fail with error: groovy.lang.MissingPropertyException: No such property name for class…
If I change the code by replacing it.name with just it , as follows, then it works as expected:
modes.any {it == evt.value}
Please help me save my hair, not much left to pull out. What am I doing wrong here:
Thanks for your help.
