Hey guys, I’m looking for a thermostat that is compatible with a heat only system (Zones hot water baseboard) that has two wires, and can be integrated with ST. I heard the Nest works well but its a bit expensive
- any recommendation will be highly appreciated.
You have a lot of choices - Nest, Ecobee, zwave. You want something zwave / wifi enabled.
If you are in USA, you should check if your power company or energy save for your state/region give rebates for wifi thermostats.
In many parts of the USA they do give you 100$ which can help for what you buy.
I would check with your power company.
With the exception of the Nest, will either one of the others work with out a C-wire?
