For some reason, the method temperatureChangedHandler is never fired. I’ve tried with both the virtual temperatureMeasurement device and one of my SmartThings Multisensors. Does anyone see something wrong in this:
* Thermostat Mode Changer
* Copyright 2016 Jeremy Beckham
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Thermostat Mode Changer",
namespace: "jbeckh2",
author: "Jeremy Beckham",
description: "Changes the mode of a thermostat when the temperature of a sensor gets too cold or too hot.",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Change this Thermostat's:"){
input "thermostat", "capability.thermostat", required:true, title: "Thermostat?"
section("Mode to:"){
input "desiredmode", "enum", required:true, title:"Mode", options: ["heat", "cool", "off", "auto"]
section("When this temperature sensor:") {
input "sensor", "capability.temperatureMeasurement", required: true, title: "Sensor?"
section("Is Less Than or Is Greater Than") {
input "lessorgreater", "enum", required:true, title:"Less Than/Greater Than", options: ["less", "greater"]
section("This Temperature") {
input "triggerTemp", "number", title:"Temperature"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
// TODO: subscribe to attributes, devices, locations, etc.
subscribe(sensor, "temperature", temperatureChangedHandler)
// TODO: implement event handlers
def temperatureChangedHandler(evt) {
log.debug "Temperature Changed Detected ${evt}"
if (desiredmode != thermostat.thermostatMode) {
if (lessorgreater == "less") {
if (evt.doubleValue < triggerTemp) {
updateMode()
} else {
if (evt.doubleValue > triggerTemp) {
updateMode()
def updateMode() {
thermostat.setThermostatMode(desiredMode)
