Sylvania Lightify RGB Tunable White A19 $20
On sale at Menards:
Sylvania OSRAM Lightify Smart Connected 9.5 Watt A19 Adjustable to Red Blue Green as well as Tunable White (2700K to 6500K) LED Home Automated Light Bulb, Model 73922
$20
https://www.menards.com/main/p-1444431939952.htm
Not sure if this is good deal or not, so many different yet similar combinations/kits and model numbers come up on amazon; but not this exact bulb.
Lowes shows $10 but unavailable, also says “full spectrum”, that sounds like RGB?
https://www.lowes.com/pd/SYLVANIA-LIGHTIFY-60-W-Equivalent-Dimmable-Full-Spectrum-A19-LED-Light-Fixture-Light-Bulb/1000083113
Lowes bulb 9.99
LED bulb tunable between soft white and daylight white (1900-6500 Kelvins) and thousands of color options.
I’m having a bunch of block delivered soon. maybe a should add a few bulbs on the order.
The ones in Lowe’s are not RGB. My orders got cancelled after a month.
They both show Model Number: 73922, so neither is RGB?
Osram sells tunable white and RGBW bulbs. Their RGBW are usually the more expensive around $40 on average. The tunable whites are about $20 (A16). They also have BR30s.
The Lowes bulbs are RGBW, but they hit $9.99 on clearance a couple of weeks ago. If you find a store with any in store, consider yourself lucky.
LIGHTIFY 10-watt (60 watt equivalent) RGBW A19 medium base (E-26) LED dimmable Indoor LED Bulb with Built-In WiFi
I was able to snag one of the tunable white bulbs for $7. The rest of DFW is cleared out. There’s a few floods and the yellow bulbs left here and there. I’m going to bug my folks in Ohio and see if they can snag a few more.
