Sump Pump Power Monitor
This SmartApp will allow you to use a power/energy monitor to recieve a notification or text message if your sump pump has cycled on.
The app has been tested with an Aeon Labs Z-Wave Smart Energy Switch.
This device is rated up to 1875W 15A so be aware of the starting watts of your sump pump when considering this app.
Cheers,
GitHub
* Sump Pump Power Monitor
* Copyright 2014 Chad Schone
* Based on https://github.com/sudarkoff/smarttings/blob/develop/BetterLaundryMonitor.groovy
* by sudarkoff
* Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
    name: "Sump Pump Power Monitor",
    namespace: "cschone",
    author: "Chad Schone",
    description: "Use an power meter to monitor sump pump activity.",
    category: "Safety & Security",
    iconUrl: "https://s3.amazonaws.com/smartthings-device-icons/alarm/water/wet.png",
    iconX2Url: "https://s3.amazonaws.com/smartthings-device-icons/alarm/water/wet@2x.png",
    iconX3Url: "https://s3.amazonaws.com/smartthings-device-icons/alarm/water/wet@3x.png")
preferences {
    section ("When this device starts drawing power") {
        input "meter", "capability.powerMeter", multiple: false, required: true
    section (title: "Notification method") {
        input "sendPushMessage", "bool", title: "Send a push notification?"
        input "phone", "phone", title: "Send a text message to:", required: false
def installed() {
    log.debug "Installed with settings: ${settings}"
    initialize()
def updated() {
    log.debug "Updated with settings: ${settings}"
    unsubscribe()
    initialize()
def initialize() {
    subscribe(meter, "energy", handler)
    subscribe(meter, "power", handler)
    state.cycleOn = false;
    meter.reset();
    state.lastEnergy = 0
    log.trace "initialize"
    log.debug "lastEnergy: ${state.lastEnergy}"
    log.trace "Forced switch on."
    meter.on()
def handler(evt) {
    log.trace "handler"
    def currentEnergy = meter.currentValue("energy")
    def currentPower = meter.currentValue("power")
    //def currentState = meter.currentValue("switch")
    log.trace "Current Energy: ${currentEnergy}"
    log.trace "Current Power: ${currentPower}"
    //log.trace "Current Power: ${currentState}"
    def isRunning = (currentEnergy > state.lastEnergy) || (currentPower > 0)
    if (!state.cycleOn && isRunning) {
        // If the sump pump starts drawing energy, send notification.
        state.cycleOn = true
        def message = "Check your sump pump!"
        log.trace "${message}"
        send(message)
    } else if (state.cycleOn && isRunning) {
        // If the sump pump continues drawing energy,
        // send more notifications.
        def message = "Your sump pump is still running!"
        // this is probably overkill
        //send(message)
    } else if (state.cycleOn && !isRunning) {
        // If the sump pump stops drawing power, send notification.
        def message = "Your sump pump stopped running!"
        send(message)
    } else {
        // this should not happen
        log.trace "No activity."
    state.lastEnergy = currentEnergy;
    // negate physical on/off switch
    // If using this device as a monitor it shold never be off
    //if(currentState == "off") {
    //    log.trace "Forced switch on."
    //    meter.on()
private send(msg) {
    if (sendPushMessage) {
        sendPush(msg)
    if (phone) {
        sendSms(phone, msg)
    log.debug msg
I could not get this to work with a Smartthings Plug. I’m able to see it my apps, go into setup and select the plug, When I hit “done” it says app is installed and automating, but then comes back with “unexpected error”.
Has anyone got any advice?
I have the same need. I loaded this SmartApp and it notified my last night, but only that the sump pump turned on. I posted a new request (as a new user with little knowledge how to build a custom app) here, so hopefully someone can advise, or I can learn to clean up this app
