I have a very simple prototype I’m trying to hook up to OAuth - eventually I want my BBQ Pit monitor to push values to my smartapp (until I get tot he point where I can have it push values to a device). Let me go through the steps and have you guys take a look and point out where I’m being stupid.
First, the simple smartapp:
* pit monitor v3
* Author: jameslew@live.com
* Date: 2014-01-07
definition(
name: "pit monitor v3",
namespace: "jameslew",
author: "jameslew@live.com",
description: "Monitoring the BBQ Pit via @SmartThings",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png")
preferences {
section ("BBQ Temps to Threshhold At..."){
input "switches", "capability.switch", title: "Vestigal switches", required: true
input "foodDoneTemp", "number", title: "Food Done Temperature", required: true
def installed() {
def updated() {
mappings {
path("/updateTemps/:pitTemp/:foodTemp") {
action: [
PUT: "updateTemps"
void updateTemps() {
So theoretically, this has one call in (updateTemps), and a vestigial switch so SmartThings has something to give access to - even though I don’t need it.
So I register this, and turn on OAuth, so I get my Oauth ClientID and ClientSecret. From there:
Get an oauth Code:
https://graph.api.smartthings.com/oauth/authorize?response_type=code&scope=app&client_id=<myclient>&redirect_uri=http%3A%2F%2F127.0.0.1%3A8080%2Fauth%2Fsmartthings%2Fcallback
Use the code, my clientid, and clientsecret to get an accesstoken:
https://graph.api.smartthings.com/oauth/token?grant_type=authorization_code&client_id=<myclient>&client_secret=<mysecret>&&redirect_uri=http%3A%2F%2F127.0.0.1%3A8080%2Fauth%2Fsmartthings%2Fcallback&scope=app&code=<mycode>
Use the accesstoken & clientid to enumerate my endpoints:
https://graph.api.smartthings.com/api/smartapps/endpoints/<myclient>?access_token=<mytoken>
Which returns something like:
oauthClient: {
clientId: "<client id>",
authorizedGrantTypes: "authorization_code"
url: "/api/smartapps/installations/<guid>"
I then assume I build my call to the service using the installations url which gives me:
https://graph.api.smartthings.com/api/smartapps/installations/<installationid>/updateTemps?access_token=<accesstoken>
Where updateTemps is the name of the method I wish to call. From this I get:
error: true,
type: “SmartAppException”,
message: “Not Found”
I also tried with the parameters to the method
https://graph.api.smartthings.com/api/smartapps/installations/<installationid>/updateTemps/225/130?access_token=<accesstoken>
and get
error: true,
type: "SmartAppException",
message: "Method Not Allowed"
So where am I going wrong? This seems like it should work but I’m apparently doing something stupid.
BTW: When you add your vestigial controllable device to your app, it has to be first in the preferences section or you’ll get a weird error.
Ideas?
Glad I could help.
