Hi, I use a GE switch, they have a led indicator, I use this indicator to show the alarm status, very useful, the indicator can be turned on and off.
Its free if you already have a ge/jasco switch next to door
There are a couple of light switches which have an LED indicator light which can be turned on and off from SmartThings. The newest homeseer switch is actually intended for this purpose, but there are some other brands as well. ![]()
The homeseer is interesting because it also allows for double and triple tap, so you can use a single tap to turn the switch on and off, and a double tap to arm and disarm your security system, changing the color indicator light at the same time.
https://shop.homeseer.com/collections/lighting/products/hsws200
