Newbie ST user here. Have v2 hub (firmware: 000.014.00013) working with an (1) ST outlet and (3) ST multi sensors on doors for open/close alerts. Setup has been working perfectly the past 2 weeks.
Yesterday I added an Aeon Siren (Gen5) without a problem. Set it up to go off when a door multi sensor opens as part of my Good Night routine. All tests worked flawlessly.
Went to bed at 11pm, fell asleep and at 11:45pm (EST) the alarm tripped because of 1 of the sensors being opened. The feed showed it opened at 11:45 and then closed at 11:45. Obviously I checked door and it had not been opened.
It did the same thing at 5:46am, luckily I was smart enough to make alarm inactive after the first false.
Any ideas on the cause? Would like to use this siren but my wife will kill me if I scare her like that again. Thanks for your help!
