@zambobmaz can you please add to your driver:
model : TS0046
manufacturer : _TZ3000_nrfkrgf4
Updated and Applied (2025-05-29T10:03:28.243985123)
Thank You so much, works perfectly. Will eventually report on battery life.
It’s now December and both 6 button switches show a battery level of 100%. They both work very well so far. _TZ3000 _nrfkrgf4 TS0046. Nothing being perfect, the casing for those switches is not very impressive. There was a mechanical interaction between buttons. That got fixed by filing the area between buttons just a little bit. The buttons come off by simply pulling them out. There is only one LED for all six buttons so drilling a little hole (while the button is removed from the switch of course) in front of the blue LED makes it much more visible.
With all three _TZ3000_wkai4ga5 TS0044 that I was using in the past, batteries had to be replaced at an alarming rate…
i have a moes 4 button zigbee remote thats working great using the button-battery-v1.4.4 driver each button has press double press and hold it no longer allows me to add actions to the double press / hold functions (see picture)
when i press one to change it i get
any help would be great .
thanks
martin
Did you tried to use routines ? Is routines allow you to trigger from the Zigbee remote ?
hi yes i can create rutines but should be able to do it there.
thanks
regarding the battery drain, i have 6 of these MOES 4 button switch, i realised that its always the same 3 switch that keeps draining battery, i have to change batteries every week or so. Could it be the version of the MOES switch draining battery?
Hello @erickv, could you please add this other variant to your driver?
Manufacturer: _TZ3000_j70oanab
Model: TS0044
Profile: 4-button-battery
Thanks in advance
Try to open an issue in @zambobmaz GitHub and he will add to his driver:
Hello, @junkai21
Apparently, this “issue” comes with certain devices. So far, I’ve been able to identify the following behavior
- DIMMER mode is not supported (i.e. Zigbee Groups)
- On SCENE mode, every press is now working accurately, where before there was a 3-second lag between each press.
- Battery drains faster even with the lower-as-possible health check rate.
Or at least that has been my experience as well
@dotan_shai Thanks for mentioning me. I updated and applied (2025-09-10T11:47:17.526317992)
I am trying to use a MOES IP55 Smart Button with @erickv drivers, version 1.4.5, but it’s not working. Help?
This is a single button that is exterior-rated that has a lot of generic versions.
I got the device paired and it exposes one or more buttons in the driver. It reports battery at 100%, but when I press or hold the button, nothing happens at all.
Model info is: TS004F, Manufacturer (Code) is _TZ3000_kjfzuycl.
Try zambobmaz driver
Fingerprint:
- id: _TZ3000_kjfzuycl/TS004F
deviceLabel: Tuya 1 Button
manufacturer: _TZ3000_kjfzuycl
model: TS004F
deviceProfileName: zigbee-tuya-button-1
Yes, I tried that one first, and it doesn’t work. No events are being recognized. I changed drivers around and tried that driver again, but same result: no events.
Hello @SeanTek
Thanks for reaching out with this request.
I reviewed the current fingerprint and did some digging about it and I found this:
- It expects a 2-button device.
- It was originally integrated for the device mentioned in this post: [ST Edge] Zigbee Driver for MOES 4-Button Scene Switch (TS004F) Plus Some Smart Knob Models - #164 by sulisenator
So, probably when I added such fingerprint I missed on the profile on the device which should have been a single button device, am I right?
Please confirm this information so I can update the fingerprint and give it a try.
That is possible.
Here is the product:
I’ll push an update on the button-battery-v1.4.5 to update the profile.
Please, let me know if it changes anything (fingers crossed), so I can keep looking if it doesn’t.
Okay, please post when the update is pushed and I will try to refresh/test about 6 hours afterwards.
The latest update in v1.4.5 is live, so keep me posted.
I used it last night, but it didn’t help.
The driver version is 2025-12-17T19:01:30.96202737.
The button reports some features (including dimmer features, don’t know why) but when I press the button, nothing happens. The green LED indicator underneath the backside of the button blinks on press so mechanically the button should be working.
