The example for Display Type list includes the following reference:
"supportedValues": "supportedThermostatModes.value"
What data type is expected and how should the value be formatted?
It is an array of strings. An example using the similar supportedButtonValues
in a driver is:
device:emit_event(capabilities.button.supportedButtonValues({"pushed","held","double"}))
OK, that’s what I thought. Maybe the array helper only exists for particular attributes?
I have a custom capability with an attribute named filter which is used in a list presentation as “supportedValues”: “filter.value”. If I set filter as “`type”: “string”, I can set it to a string and my list goes empty which makes sense. However, if I set filter as “type”: “array”,
"filter": {
"schema": {
"type": "object",
"properties": {
"value": {
"type": "array"
"additionalProperties": false,
"required": ["value"]
then device:emit_event(fanSpeed3.filter({"Off", "Low", "High"}))
generates the error
TimeStamp ERROR MyDriver MyDevice thread encountered error: [string "st/dispatcher.lua"]:229: Error encountered while processing event for <Device: MyDeviceID (MyDevice)>:
arg1: added
arg2: table: 0xb2aff8
It sure looks like it doesn’t know what to do with a table regardless of the underlying attribute type.
I don’t really pretend to understand these schema thing. I notice that in the button
capability the value
has a bit more to it …
"value": {
"type": "array",
"items": {
"title": "ButtonState",
"type": "string",
"enum": [
"pushed",
"held",
"up_hold"
Could that extra bit of structure be important?
Yes, that makes a difference. The error is gone. I think I must have the keys/values reversed because my list is blank.
EDIT: Works as expected. Don’t know if I’ll ultimately have a need for this, but at least we know (how) it works. This is one of the few ways to dynamically alter the UI. Thanks for your help!
