[ST Edge] Rain radar (Buienradar NL/BE, Open-Meteo worldwide): rain now, starts in, lasts, with radius (small bridge)
Rain radar in SmartThings: is it raining at home, how hard, when does it start and how long does it last, two hours ahead. In the Netherlands and Belgium from Buienradar (radar, 5 minute steps), everywhere else from Open-Meteo (15 minute steps, no account needed). Through the small Stoeckie Bridge (Windows or Docker) and its Edge driver.
What you get
A Buienradar device with the setting Show:
  • Detail (default): rain detected or not, intensity (none, possible, light, moderate, heavy, violent), rain now in mm/h, rain starts in (minutes), rain lasts (minutes) and a short summary
  • Rain or dry only: just the rain sensor
  • Location by Dutch postcode and house number (PDOK), by any address worldwide (OpenStreetMap), or by latitude, longitude. Looked up once
  • Source: Auto (Buienradar in NL/BE, Open-Meteo elsewhere), Buienradar or Open-Meteo
  • Summary in English (the app does not translate device texts)
  • Radius in meters (0 to 25000): rain anywhere within it counts. With a radius the bridge also reads up to 16 points around the address and takes the heaviest rain per 5 minutes
  • Rain from (mm/h): adjustable, default 0.1
  • Dew point now and Dew point max (forecast): the outdoor dew point now and the highest in the next 48 hours (6 to 72 adjustable), from the Open-Meteo hourly forecast, refreshed every hour. For routines that look ahead, e.g. keep a crawl space dryer on when humid air is coming (see post 8)
  • All settings are on the Buienradar device in the SmartThings app
  • Everything works in routines, e.g. rain starts in less than 15 minutes > close the windows, rain detected > notification, rain lasts more than 30 minutes > blinds down
Install
  1. Install the bridge and the driver from GitHub - Stoeckie/smartthings-stoeckie-bridge: Stoeckie Bridge: cloud appliances (AEG/Electrolux, Fujitsu FGLair, Škoda, iRobot favorites) in SmartThings. Bridge for Windows or Docker plus Edge driver · GitHub (Windows: install.bat, Docker: docker compose up)
  2. Enroll your hub: SmartThings. Add a little smartness to your things. (Stoeckie Edge Drivers) and install Stoeckie Bridge (local). Add device > Scan nearby
  3. Settings of the Stoeckie Bridge device: switch on Rain radar. A Buienradar / Rain radar device appears
  4. Settings of that device: postcode and house number (NL), an address or latitude, longitude, radius in meters, rain from (mm/h), source, what to show and the dew point look ahead. The bridge setup page has the same fields
Developer notes
Running here in the Netherlands. Feedback welcome.
Tip: also a “back online” notification
If you made the Offline routine (Stoeckie Bridge (rain radar) device, Connection is Offline, send notification), duplicate it in the app and change the condition to Connection is Connected, with a text like “Stoeckie Bridge (rain radar) is back online”. Then you know the problem is over without opening the app. The device also shows Last drop (when, how long, why).
README updated with the same tip.
Rain radar bridge: new version 2026-11-06c
Nothing changed in the rain logic. What is new: the setup page (location, radius, interval) is in English, and Docker users can reach it from a regular browser on their Docker machine at http://localhost:8787/setup, with or without host networking. For setup from a different computer, list its IP in STBRIDGE_SETUP_ALLOW and open https on port 8443 (README section 1b).
Update with git pull plus docker compose up -d --build, or copy the files and run install.bat on Windows; settings stay.
Update (bridge 2026-11-06e): summary always in English
The short rain summary on the device was Dutch in the Netherlands and Belgium and English elsewhere. Device texts are not translated by the SmartThings app, so it is now English for everyone, for example “Rain in 20 min, for 15 min, up to 1.2 mm/h”. Nothing else changed; routines on rain now, starts in and lasts work as before.
Fix (driver 2026-11-06f): location settings could get lost
The postcode, address or coordinates you set on the rain radar device were only sent to the bridge at the moment you changed them. If the bridge was restarting or unreachable right then, it kept using no location (the setup page then shows “no location, radius 0 m”). The driver now sends them again every time it starts, so they always end up on the bridge. Nothing to do: the driver updates on the hub by itself. Check the setup page after the update; it should show your place again.
Rain radar: bridge 2026-11-06g, Python 3.13
To update, run install.bat on Windows (it fetches Python 3.13 and rebuilds the bridge, location and radius settings stay) or rebuild the Docker image. Combined with the location fix above, the rain radar keeps its place after every restart. Also new on the same bridge: local Home Connect dishwashers and ovens, [ST Edge] Home Connect (Bosch, Siemens, Neff) dishwasher and oven, local without cloud: status, door, temperature, stop (small bridge)
Small heads up for anyone running the bridge: version 2026-11-07a switches to Python 3.14 for security updates on Windows. The rain radar itself is unchanged. To update: Windows, run install.bat once more; Docker, git pull and docker compose up -d --build (the image is now python:3.14-slim).
New (bridge 2026-11-07e, driver 2026-11-07b): dew point forecast on the rain radar device
The rain radar device now has two extra values you can use as routine conditions:
  • Dew point now: outdoor dew point in °C.
  • Dew point max (forecast): the highest outdoor dew point in the next 48 hours. The look ahead is a setting on the device (Dew point forecast (hours), 6 to 72).
Both come from the Open-Meteo hourly forecast (in the Netherlands the KNMI model) for the same location as the rain radar, refreshed every hour. Buienradar’s free feed only has humidity as a station measurement, not as a forecast, so this part always uses Open-Meteo. If that fetch fails the rain radar keeps working.
Why: I use it for a dryer in a crawl space that should switch at most once a day (it runs on for 10 minutes after switching off). At 14:00 it turns on when the crawl space humidity is 85% or more, or when Dew point max is 11 °C or more (humid air on its way). It turns off when the humidity is 80% or less and Dew point max is 8 °C or less, because then ventilation dries the crawl space by itself.
The device switches to a new profile by itself after the driver update (it gets two extra components). To update: run update or install.bat on Windows, or git pull and rebuild the Docker image. Details in the README: GitHub - Stoeckie/smartthings-stoeckie-bridge: Stoeckie Bridge: cloud appliances (AEG/Electrolux, Fujitsu FGLair, Škoda, iRobot favorites) in SmartThings. Bridge for Windows or Docker plus Edge driver · GitHub
