When I pair the First Alert Smoke and CO Detector (ZCOMBO) with the stock ST beta Z-wave Smoke Detector driver I have the following problems:
- CO shows off line and does not respond to testing.
- When I test the unit the only way to reset it is to remove the batteries and re-install them.
Any advice in how to fix this?
The fingerprints match.
IDE finger print: zw:S type:A100 mfr:0138 prod:0001 model:0002 ver:0.05 zwv:3.52 lib:06 cc:20,80,70,85,71,72,86
Driver Fingerprint:
- id: “FirstAlert”
deviceLabel: First Alert Smoke Alarm
manufacturerId: 0x0138
productType: 0x0001
productId: 0x0002
deviceProfileName: smoke-co-battery
pairing Logs:
2022-03-29T00:27:47.496780186+00:00 TRACE Z-Wave Smoke Alarm Setup driver zwave_smoke_co_detector with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_smoke_co_detector
default_handlers:
driverSwitched:
infoChanged:
init:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V1
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V2
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V2 → Fibaro CO sensor zw5
default_handlers:
init:
doConfigure:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_smoke_co_detector → fibaro smoke sensor
default_handlers:
added:
child_dispatchers:
2022-03-29T00:27:47.502358436+00:00 TRACE Z-Wave Smoke Alarm Setup driver zwave_smoke_co_detector with Capability handlers:
CapabilityCommandDispatcher: zwave_smoke_co_detector
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V1
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V2
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V2 → Fibaro CO sensor zw5
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_smoke_co_detector → fibaro smoke sensor
default_handlers:
child_dispatchers:
2022-03-29T00:27:47.507067061+00:00 TRACE Z-Wave Smoke Alarm Setup driver zwave_smoke_co_detector with Z-Wave handlers:
ZwaveDispatcher: zwave_smoke_co_detector
default_handlers:
SENSOR_BINARY:
REPORT
SENSOR_MULTILEVEL:
REPORT
SENSOR_ALARM:
REPORT
NOTIFICATION:
REPORT
WAKE_UP:
NOTIFICATION
BATTERY:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V1
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V2
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_smoke_co_detector → Z-Wave smoke and CO alarm V2 → Fibaro CO sensor zw5
default_handlers:
CONFIGURATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_smoke_co_detector → fibaro smoke sensor
default_handlers:
WAKE_UP:
NOTIFICATION
child_dispatchers:
2022-03-29T00:27:47.533432644+00:00 TRACE Z-Wave Smoke Alarm Received event with handler resync
2022-03-29T00:27:47.537532227+00:00 TRACE Z-Wave Smoke Alarm Received event with handler environment_info
2022-03-29T00:27:47.558345561+00:00 TRACE Z-Wave Smoke Alarm Found DeviceLifecycleDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:27:47.577422769+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:27:47.582016936+00:00 TRACE Z-Wave Smoke Alarm Received event with handler environment_info
2022-03-29T00:27:47.585058728+00:00 DEBUG Z-Wave Smoke Alarm Z-Wave hub node ID environment changed.
2022-03-29T00:27:47.596081019+00:00 TRACE Z-Wave Smoke Alarm Received event with handler device_lifecycle
2022-03-29T00:27:47.599220728+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received lifecycle event: added
2022-03-29T00:27:47.604185144+00:00 TRACE Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received unhandled lifecycle event: added
2022-03-29T00:27:47.607326186+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:27:47.610675103+00:00 TRACE Z-Wave Smoke Alarm Received event with handler device_lifecycle
2022-03-29T00:27:47.613928853+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received lifecycle event: doConfigure
2022-03-29T00:27:47.619591311+00:00 TRACE Z-Wave Smoke Alarm Found DeviceLifecycleDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:27:47.622807269+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:27:47.632630894+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:27:47.844791436+00:00 TRACE Z-Wave Smoke Alarm Received event with handler device_lifecycle
2022-03-29T00:27:47.854897228+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received lifecycle event: infoChanged
2022-03-29T00:27:47.860641269+00:00 TRACE Z-Wave Smoke Alarm Found DeviceLifecycleDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:27:47.863793728+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:28:28.252251664+00:00 TRACE Z-Wave Smoke Alarm Received event with handler unnamed
2022-03-29T00:28:28.259569872+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received Z-Wave command: {args={battery_level=95}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="", src_channel=0, version=1}
2022-03-29T00:28:28.275483789+00:00 TRACE Z-Wave Smoke Alarm Found ZwaveDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:28:28.279613955+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> emitting event: {“capability_id”:“battery”,“state”:{“value”:95},“attribute_id”:“battery”,“component_id”:“main”}
2022-03-29T00:28:28.289426205+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:28:28.368533164+00:00 TRACE Z-Wave Smoke Alarm Received event with handler unnamed
2022-03-29T00:28:28.375343497+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received Z-Wave command: {args={battery_level=95}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="", src_channel=0, version=1}
2022-03-29T00:28:28.384803955+00:00 TRACE Z-Wave Smoke Alarm Found ZwaveDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:28:28.388403539+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> emitting event: {“capability_id”:“battery”,“state”:{“value”:95},“attribute_id”:“battery”,“component_id”:“main”}
2022-03-29T00:28:28.397005747+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:28:28.668565747+00:00 TRACE Z-Wave Smoke Alarm Received event with handler unnamed
2022-03-29T00:28:28.675013955+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received Z-Wave command: {args={battery_level=95}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="", src_channel=0, version=1}
2022-03-29T00:28:28.684588664+00:00 TRACE Z-Wave Smoke Alarm Found ZwaveDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:28:28.688235955+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> emitting event: {“capability_id”:“battery”,“state”:{“value”:95},“attribute_id”:“battery”,“component_id”:“main”}
2022-03-29T00:28:28.696749039+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:28:29.078554122+00:00 TRACE Z-Wave Smoke Alarm Received event with handler unnamed
2022-03-29T00:28:29.084804414+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received Z-Wave command: {args={battery_level=95}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="", src_channel=0, version=1}
2022-03-29T00:28:29.094207789+00:00 TRACE Z-Wave Smoke Alarm Found ZwaveDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:28:29.097780081+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> emitting event: {“capability_id”:“battery”,“state”:{“value”:95},“attribute_id”:“battery”,“component_id”:“main”}
2022-03-29T00:28:29.106380706+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
2022-03-29T00:28:29.352459956+00:00 TRACE Z-Wave Smoke Alarm Received event with handler unnamed
2022-03-29T00:28:29.358828247+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> received Z-Wave command: {args={battery_level=95}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="", src_channel=0, version=1}
2022-03-29T00:28:29.369203997+00:00 TRACE Z-Wave Smoke Alarm Found ZwaveDispatcher handler in zwave_smoke_co_detector
2022-03-29T00:28:29.372861789+00:00 INFO Z-Wave Smoke Alarm <ZwaveDevice: 43bceff4-0b45-46e2-ae30-7a0f14c2591b [7A] (First Alert Smoke Detector)> emitting event: {“capability_id”:“battery”,“state”:{“value”:95},“attribute_id”:“battery”,“component_id”:“main”}
2022-03-29T00:28:29.382367289+00:00 DEBUG Z-Wave Smoke Alarm First Alert Smoke Detector device thread event handled
