[ST Edge/Beta] Buttons and remotes Edge Driver (Aqara,IKEA,Tuya)
I did not have that dvr yet, i will try later today & reply, thx so much
Sadly no. At least I couldn’t find one
You are referring to this?
Any luck with this?
Hi @ygerlovin,
could you please add support for this Tuya button to the Zigbee Button Remote Driver [YG]?
Model: TS0041
Manufacturer: _TZ3000_yj6k7vfo
I’m currently using another Edge driver (zigbee-tuya-button), but the long press action doesn’t work even though some users report that this model supports it. In SmartThings I can see “long press” as an option for automations, but the event is never triggered.
I’d like to try your driver because it seems to handle long press correctly for other TS0041 variants. If possible, could you add this fingerprint so I can test it?
— FYI —
After extensive testing and analyzing the driver logs, I found that:
  1. Long press DOES work - but only when the button is in a “cold” state (no presses for 10+ seconds)
  2. Long press FAILS after a recent single or double press
Hope this helps anyone experiencing similar issues with cheap Tuya buttons. Sometimes you get what you pay for
I found the device in that list, added the tuya button driver, but that driver does not show in list when i try to change driver fir it?
You can also try driver in this post
Also fingerprint _TZ3000_ja5osu5g TS004F
If your device fingerprint is :
@zambobmaz should find it and you’ll be able to use. If it is different device change back to zigbee thing MC and let us know what your device Fingerprint
