Setup:
Device: Qubino Flush Shutter DC
Model: ZMNHOD1
Custom device handler: https://github.com/kjamsek/SmartThings/blob/master/DeviceHandlers/Qubino/FlushShutter/QubinoFlushShutterDeviceHandler.groovy
Problem: I am trying to control my window blinds(separate tubemotor) but I am stuck with an error message when I try to change the state of the blinds.
When I try to change the state of my window blinds, in the smartthings app, I get an error pop up saying “A network or server error occured. Try again later”. I don’t get any output to the motor I am trying to run. I have checked and there is no problem with either the motor, power supply or network connection.
The flush shutter is conected on Q1 & Q2 to the motor and + & - to the powersuply.
I can trigger the motor by closing I1 or I2, but I have no luck trying to trigger it with a scene.
My solution:
Custom handlers does not seem to work for me.
Instead I used the “Z-wave switch” handlers that are default handlers in the app.
I was also using a second acount to add the device when I got the problems. When I added the device with my main acount I had no problems.
So I dont know wich of the two things caused the problem, or maybe both of them did, but after aplying these things it started working for me. So either the handler or access/authorisation was the problem.
This solution needed me to calibrate the motor it self and not the flush shutter
