I changed the name and self published.
@djsat2, Iāve tried it. And it letās you save it. But it smells fishy. So I changed one of my ST motion sensorās custom DH to run locally. When I changed it, it started to execute something else. The temperature values reverted back to integers instead of float what I prefer.
Iāve tried with an IKEA motion sensor too. Changed to local, even I did a rule for it with Smart Lighting and that was local too. But I have doubts that this is by any chance not a mistake somewhere in the IDEās code.
@Brad_ST, since when the IDE allows to save custom DHs with runLocally:true
? As it is now actually allowing it.
Could you please advise? Is it a (nasty) bug?
What is happening here is that when it attempts to run locally it isnāt going to find the corresponding DTH to run and consequently it will fall back to default local handling. In most cases that is going to be essentially the same as what our standard DTHs do (with a few minor differences here and there). So while you can set that flag, it likely wonāt result in the behavior you want. And certainly making changes in the groovy DTH you are self publishing will have no affect on the locally executing device.
Thanks @Zach_Varberg! It sounds interesting, but what about those devices, like the above mentioned zigbee metering plug, what hasnāt got a local running DH, but there are another 2 similar DHs with local execution?
Will it fall back to ādefaultā metering and local on/off execution? (What is the default for the metering values?)
Nice improvement but a bit misleading if you donāt know how it is working.
Yes, it will fall back to handling for those Zigbee messages (the simple metering and electrical measurement values) and convert those to device capability events. But in doing so, it will use a default ādivisorā for converting those values from the raw value reported by the device, to the normal way people would discuss them. In the case of these devices that default will incorrectly be 10 (as that has been the most common value we have seen from devices). So even if you make the change in the cloud and mark it to run locally, you will likely continue to get incorrect values.
The ability to set the flag was originally done because people wouldnāt be allowed to save self published versions of our official DTHs because the flag was set and it would reject them, which was very confusing for users. Letting it be set allows people some limited (and now deprecated) control of display options while still getting local execution, but as youāve stated produces some pretty confusing behavior if you arenāt an employee and canāt read the code directly. It probably should have been handled differently.
In terms of a āfixā for this issue, I canāt really make any comments about that as Iām an engineer and I donāt dictate prioritization or scheduling of work. But I have made people aware of the issue and the fact that it has been a negative experience for users.
Thanks again @Zach_Varberg. It is definitely confusing, but I understand the logic behind the change as the true flag with STās DHs stopped the saving.
Might be a banner on the top of the edit page should do the job, to change that flag to false, if you want run your custom code, when you hit save.
The disappointing thing in your sentence, that this device is the new ST Zigbee metering plug and not following the most common valueā¦ (what the previous versions did)
Anyhow, thanks for the detailed answers! It is good to know these changes, before somebody runs on it and spends time and to debug some code.
Yep, very disappointing
I knew these plugs were too good to be true. An energy metering zigbee smart plug here in Australia for $50 was unheard of. For comparison, the Hue smart plug was recently released here and sells for $70 with no energy metering but they might execute locally Well I guess these would as well if I could deal with an incorrect energy reading.
Hmmā¦so runLocally is yet another value that isnāt of any use? I thought Local Execution meant that all logic needed to run without Internet was in the Smartthings hub, like some other Home automation controllers haveā¦so that is not the case here then??
