SmartThings Shabbat mode - fridge
Hi,
i just got a new fridge rf71a9132bk. i have connected it to SmartThings app. i have Sabbath mode on my fridge and i try to make it work also from SmartThings app.
To do so, i open the SmartThings app, i read on your site to so i need then navigate to and select your refrigerator, and then tap Refrigerator options. Tap Sabbath mode.
my problem that i dont have “Refrigerator options” on my app so i dont see Sabbath mode.
as show on this link: Use Sabbath mode on your Samsung refrigerator | Samsung Canada
what is the bug?
Can you post a screenshot of the fridge options? Did you reach out to support?
Yes I have ask support help they say that it’s not support any more after the update.
I’m assuming you checked App Settings?
That’s crazy that they removed functionality! Did they get an official response from R&D or did they just ‘say’ that.
Yes i am sure. You can read the email I got.
There could be a miscommunication issue. It looks like they are treating this as a feature request. This article was written in August of 22 and the ‘new’ app was pushed out in 21. What you can do, is ask them to update the article. This will then push the task on someone else who may know more. Or try to rephrase and clarify the issue and request an email response from R&D.
Good idea.
I’ve actually built and tested something for exactly this. A bit of background: I run a free Schema Connector called Shabbat Switch — it’s a virtual switch that turns on automatically a few minutes before candle-lighting and off after Havdalah. All the timing comes from the Hebcal API, which calculates the actual astronomical candle-lighting and Havdalah times for your specific location (not a fixed weekly schedule) — it also correctly handles Yom Tov, including standalone mid-week holidays and multi-day chagim that run straight into Shabbat, as one continuous period. People use the virtual switch to trigger their own Routines (lights, plugs, etc.) around Shabbat without manual scheduling.
I’ve now extended it to also send samsungce.sabbathMode on/off commands directly to a Samsung fridge/freezer via the Devices API, alongside the switch, since that capability isn’t exposed to Routines at all. I’ve fully tested the mechanism itself — OAuth device-scope authorization, token refresh, and command delivery all confirmed working end-to-end against a real device. What I don’t know yet is how many models it actually works on, since Samsung appears to disable this exact capability server-side on some units (like the Dacor case discussed above).
If anyone wants to try it on their own fridge and report back their model + result, here’s the invite: SmartThings Channel and Drivers — even “didn’t work” reports are useful data for figuring out which models are actually usable via the API.
