Hello @nayelyz,
The modification of the zigbee colorTemperatura default libraries of firmware 41.x to correct the conversion error from ºK to Mireds and back to ºK does not work quite well.
I was modifying a driver to apply this correction from the libraries and I have seen that it works well when a ºK command is sent to the device from the app or automation and then the response is handled in mireds to emit the event in ºK: see video attached
- With this function the value in ºK (last_kelvin_set) commanded to the device is saved in storage and then it is sent to the device converted into mireds:
--- Default handler for the ColorTemperature.setColorTemperature command
--- This will send the move to color temperature command to the color control cluster
--- @param driver ZigbeeDriver The current driver running containing necessary context for execution
--- @param device st.zigbee.Device The device this message was received from containing identifying information
--- @param command CapabilityCommand The capability command table
function color_temperature_defaults.set_color_temperature(driver, device, command)
device:set_field(LAST_KELVIN_SET .. command.component, command.args.temperature)
switch_defaults.on(driver, device, command)
local temp_in_mired = utils.round(CONVERSION_CONSTANT / command.args.temperature)
device:send_to_component(command.component, zcl_clusters.ColorControl.server.commands.MoveToColorTemperature(device, temp_in_mired, 0x0000))
end
- With this other function, the response of the device is handled in mireds and if it is not null and is within the some limits of the value in ºK saved (last_kelvin_set) in the previous function, then the value (temp_in_kelvin) is emitted as the value saved in memory (last_kelvin_set ºK).
--- Default handler for the color temperature attribute on the color control cluster
--- This converts the Uint16 value of the color temperature attribute on the color control cluster to
--- ColorTemperature.colorTemperature
--- @param value st.zigbee.data_types.Uint16 the color temperature value
--- @param zb_rx st.zigbee.ZigbeeMessageRx the full message this report came in
function color_temperature_defaults.color_temperature_handler(driver, device, value, zb_rx)
local endpoint_id = zb_rx.address_header.src_endpoint.value
local component_id = device:get_component_id_for_endpoint(endpoint_id)
local temp_in_mired = value.value
local last_kelvin_set = device:get_field(LAST_KELVIN_SET .. component_id)
local temp_in_kelvin = utils.round(CONVERSION_CONSTANT / temp_in_mired)
-- Because we are converting from Kelvin to mireds and back, we often get rounding errors over the round trip
-- this value substitution insures that the number the user sets in the UI matches what is generated by the event
if last_kelvin_set ~= nil and
last_kelvin_set >= utils.round(CONVERSION_CONSTANT/(temp_in_mired + 1)) and last_kelvin_set <= utils.round(CONVERSION_CONSTANT/(temp_in_mired - 1)) then
temp_in_kelvin = last_kelvin_set
end
device:set_field(LAST_KELVIN_SET .. component_id, nil)
device:emit_event_for_endpoint(endpoint_id, capabilities.colorTemperature.colorTemperature(temp_in_kelvin))
end
But in this function a null value is stored in memory for the commanded ºK value (last_kelvin_set) and this I believe is not necessary and makes it work badly for a value received in a refresh command or a periodic color temperature report.
See video and its corresponding log attached
6000ºK Command sent:
2022-04-07T15:37:05.268284489+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> received Zigbee message: < ZigbeeMessageRx ||
type: 0x00, < AddressHeader || src_addr: 0x1EE7, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x70, rssi: -72, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x01, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0007, ZclStatus: SUCCESS, DataType: Uint16, ColorTemperatureMireds: 0x00A7 > > > >
2022-04-07T15:37:05.301288156+00:00 TRACE Zigbee Light Multifunction v6 Received event with handler zigbee
2022-04-07T15:37:05.314909156+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> received Zigbee message: < ZigbeeMessageRx ||
type: 0x00, < AddressHeader || src_addr: 0x1EE7, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x70, rssi: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x02, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff:
true > > > >
2022-04-07T15:37:05.338185156+00:00 TRACE Zigbee Light Multifunction v6 Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-04-07T15:37:05.346938489+00:00 INFO Zigbee Light Multifunction v6 Executing ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: ColorTemperatureMireds
2022-04-07T15:37:05.353619822+00:00 PRINT Zigbee Light Multifunction v6 temp_in_mired >>>>> 167
2022-04-07T15:37:05.359825156+00:00 PRINT Zigbee Light Multifunction v6 last_kelvin_set >>>>> 6000
2022-04-07T15:37:05.365911156+00:00 PRINT Zigbee Light Multifunction v6 temp_in_kelvin >>>>> 5988
2022-04-07T15:37:05.371830156+00:00 PRINT Zigbee Light Multifunction v6 Emitted temp_in_kelvin >>>>> 6000
2022-04-07T15:37:05.378374489+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> emitting event: {"attribute_id":"colorTemperature","capability_id":"colorTemperature","component_id":"main","state":{"value":6000}}
Refresh command performed in app:
2022-04-07T15:37:26.003688158+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-04-07T15:37:26.022670158+00:00 TRACE Zigbee Light Multifunction v6 Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-04-07T15:37:26.031314158+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x1EE7, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0007 > > >
2022-04-07T15:37:26.060336825+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x1EE7, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-04-07T15:37:26.074482825+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x1EE7, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-04-07T15:37:26.088609158+00:00 DEBUG Zigbee Light Multifunction v6 Luz H. Irene device thread event handled
2022-04-07T15:37:26.111436491+00:00 TRACE Zigbee Light Multifunction v6 Received event with handler zigbee
2022-04-07T15:37:26.131728825+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> received Zigbee message: < ZigbeeMessageRx ||
type: 0x00, < AddressHeader || src_addr: 0x1EE7, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x6C, rssi: -73, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x06, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0007, ZclStatus: SUCCESS, DataType: Uint16, ColorTemperatureMireds: 0x00A7 > > > >
2022-04-07T15:37:26.162864158+00:00 TRACE Zigbee Light Multifunction v6 Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-04-07T15:37:26.171879491+00:00 INFO Zigbee Light Multifunction v6 Executing ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: ColorTemperatureMireds
2022-04-07T15:37:26.179670491+00:00 PRINT Zigbee Light Multifunction v6 temp_in_mired >>>>> 167
2022-04-07T15:37:26.185571491+00:00 PRINT Zigbee Light Multifunction v6 last_kelvin_set >>>>>
2022-04-07T15:37:26.193177491+00:00 PRINT Zigbee Light Multifunction v6 temp_in_kelvin >>>>> 5988
2022-04-07T15:37:26.210383825+00:00 INFO Zigbee Light Multifunction v6 <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> emitting event: {"attribute_id":"colorTemperature","capability_id":"colorTemperature","component_id":"main","state":{"value":5988}}
As the saved value (last_kelvin_set = nil) then the value converted from mireds to ºK is emitted and will be different from what was originally emitted.
Removing this code: device:set_field(LAST_KELVIN_SET … component_id, nil) in function color_temperature_defaults.color_temperature_handler
everything works perfectly.
Also have to change the way to send color temperature commands manually. You have to add the function to save the commanded value in ºK before sending the command:
device:set_field(LAST_KELVIN_SET … command.component, command.args.temperature).
I have seen that in zigbee switch stock driver some subdrivers, which handle this manually need to be modify.
