Looking for new thermostat since my tuya one is not compatible
Any recommendations ?
EDIT: TO be more specific, im looking for mains powered, electric floor heating thermostat…
What country are you in? The device selection does vary.
Europe, Finland
Netatmo has a nice unit which is on the official compatibility list:
You would probably need to check with them to make sure it would work with your specific heating equipment.
Thnx, i updated my question, its more specific now, and should have been right from the start
This one i have now :
It’s a bit of an elaborate integration for a single thermostat due to the number of steps involved, but my Heatmiser integration supports their Neostat electric underfloor thermostats
This one ? Does it need this neohub mentioned ?
Yup that’s the issue, needs a neohub aswell, and for Smartthings you need to run a tiny esp8266 bridge (0.3W) (though other smart home platforms don’t need the bridge). For a single thermostat it’s probably not worth it, though it is a great device
Hey Tontze:
Are you still using these? Did they work with Smartthings out of the box? I live in Finland as well and am looking for something to replace my manual floor heating thermostats. I have 5 thermostats so the price for this is pretty tempting.
Yeah still using, there is no easy solution for this. Maybe some z-wave ones could work
Ok. So you use them via a separate app or something?
yeah i have it on homeassistant, but it has problem that it shows double temperatures, and there is no control over it. I also use smart life mobile app for it.
What are the latest recommendations for SmartThings-compatible thermostats for electric floor heating in the EU, particularly in Finland? I am considering buying a TUYA Smart thermostat (85 €), as I haven’t found a suitable one that supports SmartThings and can easily replace the current thermostat. I need a smart thermostat for bathroom electric floor heating at my summer cottage. Thank you!
