Smartthings Button smartapp
I just bought a samsung smartthings button and I need to create an app to send a webrequest whenever the button is pressed.
I already started to write the code, but it is not working so far.
Can you tell me what is wrong and how to make it work?
definition(
namespace: “smartthings”,
author: “SmartThings”,
description: “Call webhook when button is pressed.”,
category: “Convenience”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet@2x.png
preferences {
section(“When this Button is Pressed”) {
input “buttonDevice”, “capability.button”, title: “Notify”
def installed()
log.debug “Installed with settings: ${settings}”
subscribe(buttonDevice, “button”, buttonEventHandler)
initialize()
def updated()
log.debug “Updated with settings: ${settings}”
unsubscribe()
def initialize() {
// TODO: subscribe to attributes, devices, locations, etc.
def buttonEventHandler(evt) {
def buttonNumber = evt.jsonData.buttonNumber
log.debug buttonNumber
def deviceNetworkId = “c0a80002:50” // “10.10.0.10:3480” update with server IP in hex format
def ip = “192.168.0.2:80”
sendHubCommand(new physicalgraph.device.HubAction(“”“GET /action.php?event=button1pressed HTTP/1.1\r\nHOST: $ip\r\n\r\n”“”, physicalgraph.device.Protocol.LAN, “${deviceNetworkId}”))
log.debug “${location} - ${presence.label ?: presence.name} - ${evt.value}”
sendPush(“${location} - ${presence.label ?: presence.name} - ${evt.value}”)
What exactly isn’t working? Are you getting errors when installing/running? Or is your code not performing as intended? What is showing in your IDE log?
Hi Philh30, thanks for answering.
The goal of the app to notify a web server that the button was pressed.
This is not happening.
I checked the log and there was an error on line 59, I corrected it by removing variables on last lines log.debug and sendPush.
Now the log looks like this:
504e42e9-a799-4bba-bfca-8cb59ff4164d 6:44:48 AM: debug pushed
[504e42e9-a799-4bba-bfca-8cb59ff4164d]https://graph-na02-useast1.api.smartthings.com/ide/logs#504e42e9-a799-4bba-bfca-8cb59ff4164d) 6:44:48 AM: debug 1
504e42e9-a799-4bba-bfca-8cb59ff4164d 6:44:48 AM: debug 1
Hey, after I saved it and published it last time it started to work.
Thank you for your help.
For whoever needs a code to run according to a Samsung Button press:
evt.value is the kind of press, can be: pushed, held or double
evt.jsonData.buttonNumber is the button number
definition(
preferences {
def installed()
initialize()
def updated()
unsubscribe()
def initialize() {
sendHubCommand(new physicalgraph.device.HubAction(“”“GET /buttonpressed.php?btnid=${buttonNumber}&presstype=${evt.value} HTTP/1.1\r\nHOST: $ip\r\n\r\n”“”, physicalgraph.device.Protocol.LAN, “${deviceNetworkId}”))
log.debug “${evt.value}”
sendPush(“${evt.value}”)
Hello! I’m looking for a device handler for the Samsung Smartthings Button. The code posted here gives me multiple compiling errors. Would someone please point me to a working device handler?
Nevermind, I figured it out.
i.e. fix all double quotes
