Hi everyone. I have recently purchased Sonoff trv and some sensors, and i was ensured hu the seller that trv valves will work with ewelink hub. Unfortunattely when i received package sonoff trv did not connect to ewelink hub. I have connected Sonoff trv to smartthings hub and its is connected but as a switch, only on/off function available. Is there any way to get full controll of sonoff trv valves usung smartthings hub? Thanks in advance
Hi,
This device works with my zigbee thermostat Mc driver
Install driver from my channel
Uninstall device and reinstall with this driver
Hi. I am very new to all these thing. Hope ther is detailed instructions. Thanks
Open this link to my channel
Enroll you hub in this channel
Install driver zigbee thermostat Mc in your hub
Put you device in pairing mode
With app add new device with search nearby option.
New Device will appears in the room were your hub is
Thank You so much, it was as ease as plugin usb. thanks.
is there any chance that to get same driver for Salus TRV?
Post Salus TRVβs model and manufacturer code to @Mariano_Colmenarejo
it is not in my device list. i believe it only works with Salus hub, i was trying to find the device but nothing appears. however i have device model and id on the valve. if it the same.
MODEL-TRV10RFM; ID-001E5E09020DEC37 (0715)
Device is Zigbee device.
Could you install Zigbee Thing Mc driver. Using Zigbee Thing Mc driver is possible to read exact model, manufacturer and Zigbee clusters.
manufacturer:
model:
Server Cluster:
Client Cluster:
You can install Zigbee Thing Mc driver from Marianoβs Edge drivers Shared Channel.
After driver installation try to pair device to SmartThings Hub.
I see Mariano has already helped you, so just for the sake of completeness: Sonoff do have their own Edge driver for their TRV.
thank you very much, now i can disconnect eWelink hub and have one free socket
now i have Zigbee Thing but Salus TRV still blinking. whatβs next?
If I understood correctly you have installed Zigbee Thing Mc driver to your hub.
Next step:
In ST App put your hub in pairing mode ( Add device and then Scan nearby ) and then put Salus TRV in pairing mode.
this driver not working. The valve was connected but without any functions of the device. and also now i have an issue with the TRV, it not updating information
yes already done. in my device list i have a new device Zigbee Thing,
Can you publish something similar to this from Zigbee Thing deviceβs history
if only i knew how
In Detail Viewβs right bottom corner is History
Try refresh
Pull from top to bottom of the screen
