Smart radiator valves
I am trying to use smart radiator to control my central heating which in turn will call on or off a pump
I have tried the following scenes is there anything wrong with these?
If valve 1 current temp < 20c then run switch to turn on pump
If valve 2 current temp <20c then run switch to turn on pump
There are 5 valves all told and the scene is run in the if any calls then turn on pump.
To turn off the pump a new scene similar to the one above eg
If valve 1 current temperature > 21c then turn off switch
Ditto valve 2 etc
This scene is run in the if all cases are met.
These scenes dont seem to work well is there a fundamental error or should i be using one of the other options on the valve eg set temperature
Brand and model of the smart valves?
From Aliexpress model HY36xRT
